How To Add/Remove Z-wave device and run a Network Rediscovery with Qolsys IQ Panel
This guide covers the various Z-Wave pairing processes with the Qolsys IQ Panel 2/2+ , the IQ Panel 4 series, and IQ Panel 5 Series
1. How to Remove a Z-Wave device from the parent network.
An often overlooked step in the process. In order to remove a device from its parent network. Always do this first when adding a device, because it may still have network data saved within its Z-wave radio and this needs to be cleared before it can be added to a new panel.
  • Navigate to the Settings Tray and click Settings
  • Click Advanced Settings
  • Enter your Installer Code
  • Click Installation
  • Then Devices
  • Z-Wave Devices
  • Clear Device.
  • While the panel is listening, utilize the Z-Wave devices add/remove feature (see device manual)
2. Add a Z-Wave device
Once the device is disassociated from any parent network, its time to add it to the panel.
  • Then Devices
  • Z-Wave Devices
  • Add Device
3. Run a Z-Wave Network Rediscovery
A very important step to follow whenever you make any new changes to your Z-Wave network. The Network Rediscovery ensures the best possible communication route for your network. To run a Network Rediscovery:
  • Click on System Tests
  • Z-Wave Tests
  • Network Rediscovery+
  • Select all devices via the checkbox
    -Click Rediscover
How To Pair an Alarm.com Smart Thermostat ADC-T3000 to a Z-Wave Network
How To Set Up a Z-Wave Network
Just received IQ2+
Switching from 2gig GC3 to IQ2+ 345
Switch to Iq panel
Unable to operate August Smart Lock from IQ2+
Remote Temperature Sensors not enrolling
Schlage Lock - Communication Issues
Switch from Frontpoint confirmation
Process To Upgrade Panel
Something went wrong message while adding devices
Z wave hook up to IQ2
Total system failure?
ZWAVE Light Switch Not Available on ALARM.COM
Thermostat delayed temperature update
IQ Panel 4 pairing IQ Siren
Thermostat Weird Behavior
How To Set Up Your New Surety System
Remove objects
Qolsys IQ Panel 4
Yale Smart lock installed with Zwave, not Zwave+
Zwave Automation Devices Wizard not working
Water Valve Not Closing
Unable to include T40K in IQ Panel zwave network
Schlage door lock malfunction after battery swap
Yale YRL236 smart lock and Qolsys 4 programming
Adc-t3000 Resistor
Device Malfunction
T2000 Notification Temp Off
Upstairs and Downstairs T3000 Thermostats Say "No Wires Detected"
Migrating from 2GIG GC2 to Qolsys IQP4003
Z-wave random pulsating dimmers
Thermostat Schedules Totally Wonky
How to connect thermostat
ADC thermostats not following scheduled temps
Trying to pair Yale assure lock 2 z wave and having issues
Honeywell T6 PRO Z-WAVE THERMOSTAT
Yale lock not responding
T2000 w/ Qolsys IQ4 -- ADC Keeps Prompting to Configure
Transferring zwave from locked IQ Panel 2+ to IQ Panel 4
Hardwired New Build, need guidance please
Aeotec Heavy Duty Smart Switches Always Going Offline (But Not Really?)
Issue with ADC SWM150 (Smart Water Valve)
Garage Door Controller Not Opening
Which smart lock
Thermostat Malfunction
Z Wave malfunction
Kwikset 888 stop working and not remove from panel
Slow/Delayed Response
All Z-Wave devices failed at once
Kwikset 888 deadbolt
Surety - Migration from Frontpoint - Pin Transfer
User codes for BE469ZP after panel swap
Current temperature way off on IQ4
How to swap old Yale lock with a new one on IQ Panel 2+
T3000 remove network failed
Sensor Left Open Energy Saver Rule not working
Qoisys panel & Zwave devices
Z-wave lights - issue on panel, but not app
Yale YRD120 Compatibility
Thermostat temp changes to Away temperature randomly
Honeywell Home TH6320zw2003
I am trying to add thermostat from my alarm.com to surety platform
Migrating from Qolsys IQ 2 panel to IQ 4 panel
ADC-SWV100 Smart Water Valve
Connecting issue
GE/JASCO Z-Wave Remote Alerts as “Unknown” after Qolsys 4.5.2 firmware update
How To Setup Your New IQ Panel 5 and IQ5 Hub
Qolsys IQ Pro questions
Garage door unable to open message
Garage door status/operation is buggy on latest update
ZWave or 2GIG still compatible?
Door lock compatibility
Add z wave devices to a new iq panel without removing them from old system
Backup and Restore Process for Qolsys Brand Panels IQ Panel 2, IQ Panel 4, IQ Panel 5 series
ADC-T40K-HD Enable time on display
Swap out a Qolsys panel
Can't re-add Yale YRD156-ZW2 to ADC app after factory reset
Alerts won’t clear
Mobiletech app and pairing adc-t25 thermostat
Sensor malfunction
How to Put IQ 2+ into exclusion mode?
Migrating from IQ2+ to IQ4
Schlage Model BE469ZP
How To Pair an Alarm.com Smart Thermostat ADC-T2000 to a Z-Wave Network
New IQ Panel 2+ Setup
GE zwave outlet not turning on/off?
Professional Monitoring & system Migration questions
Jasco outdoor smart switch
Two questions: doorbell video and lock synchronization
Programming Sensors to IQ 4
Time Settings
Garage door not reporting correctly
When adding/removing some Z-Wave devices you may need to bring the device closer to the panel to be within range. However, sometimes this is not ideal due to the nature of the devices installation (Ex Locks, In-Wall Switches, Garage, etc.) in these cases, it might be better to bring the panel to the device.
With the Qolsys panel you will need to disable Power Management to use Z-Wave functions on battery only. To do this:
  • Select Installer Settings
  • Disable Power Management
