tyler
(Tyler)
June 4, 2024, 8:53pm
38
Steps on how to Clear and Add Z-Wave devices from the IQ Panel can be found here:
This guide covers the various Z-Wave pairing processes with the Qolsys IQ Panel 2/2+ and the IQ Panel 4
1. How to Remove a Z-Wave device from the parent network.
An often overlooked step in the process. In order to remove a device from its parent network. Always do this first when adding a device, because it may still have network data saved within its Z-wave radio and this needs to be cleared before it can be added to a new panel.
Navigate to the Settings Tray and click Settings
Click Advanc…
The thermostat in use will have specific instructions on how to put the TSTAT into Include/Exclude mode. If you are referencing the T2000 from above, those instructions are here:
Steps on how to add and exclude the T2000 can be found here.
This guide covers how to get an Alarm.com Smart Thermostat ADC-T2000 into Z-Wave inclusion mode.
If you are looking for how to pair the Alarm.com T3000, see this guide here .
Should you need to know how to put your panel into Z-Wave pairing mode, you can find panel specific information below:
2GIG Go!Control, GC2
2GIG GC3
ADC T2000
[ADCT2000]
Connect the ADC T2000 thermostat to the system
Put the thermostat in OFF mode (i.e. no mode icons are lit).
Put the Z-Wave c…
General guidelines for Z-wave setup can be found here:
This guide is a reference on how to pair z-wave devices to your Z-wave compatible alarm panel.
If you would like to increase your current Z-Wave mesh network range and quality, see this post here.
One of the biggest rewards of owning an alarm system and utilizing Alarm.com is the ability to create your own smart-home network of Z-wave devices.
There is, however, a slight learning curve to the installation and troubleshooting when it comes to Z-Wave. Required steps unique to Z-wave (as oppos…
