How to swap old Yale lock with a new one on IQ Panel 2+
I assume I may need to reprogram the keypad on the lock, but hoping I don’t need to add the new lock to my IQ panel 2+ as I am using the same z-wave module used in the old one I am replacing.
I have not swapped an older Z-wave module into a newer lock, but I believe the modules are interchangeable. I would still expect to relearn it to properly sync the device and send new codes from Alarm.com. Delete that lock from your panel, then learn the new lock in near the panel before the new lock goes on the door, then run a rediscovery on the panel after it is installed.
