Kwikset 888 stop working and not remove from panel
Is the device powered and functional locally at its keypad? Have you replaced the batteries in the lock before trying other connection steps at the panel?
If the lock was factory reset, it would need to be removed and relearned into the panel. The removal steps are the same whether the lock currently works on the panel or not. The steps to follow are found at the link below:
