Smart control of your garage can add additional access and awareness to your property and there are a few different ways to set up home automation control of your garage door with Alarm.com.
With Garage Door Integration you can:
Check to see if garage doors are closed
Remotely open and close garage doors
Automatically have garage doors close when the system is armed
Receive alerts and actionable notifications if garage doors are left open
Alarm.com-Compatible Garage Door Equipment
Ecolink Z-Wave Garage Door Controller
The Ecolink GDZW7-ECO Z-Wave garage door controller is what we recommend for most Alarm.com garage door situations for the following reasons:
Works better with Chamberlain/LiftMaster MyQ garage door openers than using the Alarm.com MyQ integration
Use your garage door on the MyQ app and Alarm.com at the same time
Control your MyQ garage door with Alam.com for Apple CarPlay & Android Auto
Avoid longstanding Alarm.com MyQ integration problems
Works with non-Chamberlain/LiftMaster garage doors using the standard dry-contact button input
Controls the garage door directly from your alarm panel using Z-Wave rather than going through the cloud
Supports Z-Wave Long-Range (LR) so it communicates more reliably and at a longer distance than the Linear Z-Wave garage door controller
Linear Z-Wave Garage Door Controller
We recommend the Ecolink Z-Wave garage door controller over the Linear Z-Wave garage door controller for most situations.
Linear Wi-Fi Garage Door Opener
LDCO863B and LDCO841
Alarm.com integrates with MyQ garage doors through the cloud but there are downsides worth considering:
Alarm.com Chamberlain/LiftMaster MyQ Garage Door Integration
Alarm.com has a cloud integration for MyQ garage doors. But I don’t recommend using it. Instead, I recommend using the Ecolink GDZW7-LR Z-Wave garage door controller, which works with Chamberlain/LiftMaster Security+ 1.0 and (many) 2.0 garage door openers.
Alarm.com MyQ Integration Problems
Here is why I don’t recommend the Alarm.com MyQ Integration
When your MyQ garage door is connected to Alarm.com it can’t be used with the MyQ …
For these reasons, we recommend using the Ecolink Z-Wave Garage Door Controller to connect your MyQ garage door to Alarm.com instead.
If you still want to use the Alarm.com MyQ integration , here are the compatible parts:
Myq Garage Wi-Fi Hub/Door Sensor (821LM)
MyQ Control Panel and Internet Gateway (888LM/828LM)
LiftMaster/Chamberlain Wi-Fi Garage Door Opener
Aladdin Connect by Genie and Overhead Door by OHD Anywhere
What service plan do I need?
When using the Ecolink GDZW7-ECO, Linear Z-Wave GD00Z-X, Linear Wi-Fi, Aladdin Connect , or OHD Anywhere , you would need either of the following plans:
Surety Home
Surety Complete
When using any of the Liftmaster/Chamberlain MyQ options you would need the free Liftmaster/Chamberlain myQ add-on in addition to one of those plans. The add-on is not enabled by default and must be turned on in System Manager.
Garage compatibility guide
MyQ Wi-Fi Hub Garage Compatibility (821LM)
Before setting up MyQ garage doors on Alarm.com, consider using the Ecolink Z-Wave garage door controller instead as an alternative approach that may give you a better garage door experience.
[821lm]
821LM, 821LMB, 821LMC-S, MyQ-G0301, MyQ-G0401-ES
The LiftMaster MyQ Smart Garage Hub is a kit that allows you to integrate a wide range of Garage Door Openers with your Alarm.com account.
It supports two non-MyQ garage doors when coupled with a tilt sensor and up to 16 MyQ devices, such as an …
MyQ Retrofit Gateway Compatibility (888LM/828LM)
What items are needed for installation
MyQ Control Panel (888LM/889LM)
MyQ Internet Gateway (828LM)
[828]
Compatible door opener
LiftMaster compatible brands made after 1998
LiftMaster, Chamberlain, Sears/Craftsman, Raynor and Access opener.
ALL with a purple learn button with purple antenna wire.
M…
MyQ Wi-Fi Garage Door Controller Compatibility
LiftMaster/Chamberlain manufacture Wi-Fi enabled garage door openers that can be associated with Alarm.com accounts for integrated garage control.
If it is verified that the garage door opener is a LiftMaster/Chamberlain Wi-Fi garage door opener, no additional equipment is needed to connect the garage d…
Linear Z-Wave Garage Door Compatibility
Before purchasing the Linear Z-Wave garage controller, consider using the Ecolink Z-Wave garage controller instead as an alternative that may give you a better garage door experience.
Linear Z-Wave Garage Controller
[gd00z]
The Linear Z-Wave Garage Controller connects directly to your Garage Opener and communicates with your panel via Z-Wave to allow for remote access and automation via Alarm.com.
When considering the Linear GD00Z Garage Controller, keep in mind that it is a Z-Wave device …
What rules and notifications are available for LiftMaster and Linear garage devices?
LiftMaster and Linear garage devices have the ability to configure rules that, when triggered, perform specific actions and send notifications when a rule is triggered.
Triggers and resulting actions:
Garage door opens/closes:
This trigger can result in the following actions:
Turn on/off light
Send notifications (available for open/close)
Initiate video recording
Garage door left open:
This trigger can be set for when the garage door opener is left open for a set amount of time and/or is le…
How to Install Compatible Smart Garage Devices
[gd00z]
[821lm]
[828]
M…
Add the Genie or Overhead Door garage device using the Add Device Portal
Alarm.com Website Steps
Log into the Alarm.com Website.
Click Settings.
Click Manage Devices.
Click Add Device.
Click Garage Door.
Click Genie Aladdin Connect or Overhead Door OHD Anywhere.
Click Next.
Enter the email address and password associated with the Aladdin Connect or OHD Anywhere account, then click Sign In.
Click Authorize.
It may take several minutes before the device appears on the account.
Alarm.com Mobile …
How To Pair Smart Garage Devices with Alarm.com
Linear Z-Wave Garage Controller GD00Z-X
Once paired to the Z-Wave network, the garage should appear you in Alarm.com account automatically. You may need to log out of your Alarm.com account, then back in, to see the controller.
LiftMaster Chamberlain MyQ
Once the myQ device has been installed and is connected to Wi-Fi successfully, it can be connected to your Alarm.com account. This is done via the Alarm.com Website.
myQ devices cannot be connected via the mobile Alarm.com app at this time.
To do so:
Log in to the Alarm.com Website. (not the Alarm.co…
Click Settings.
Click Add Device.
Click Garage Door.
Click Next.
Click Authorize.
Alarm.com Mobile …
Smart Garage Troubleshooting
Reset or Change Wireless Information for Smart Garage
If your Wireless networking equipment or SSID has changed and you need to update your controller, steps on how to do so will vary by the device type in use.
Aladdin Connect by Genie and Over Head by OHD Anywhere through Alarm.com
LiftMaster myQ 821LM, 821LMB, 821LMC-S, MyQ-G0301, MyQ-G0401-ES
How to Clear Wi-Fi Settings on a myQ Wi-Fi Garage Door Opener
Remote commands are not opening or closing the garage door attached to the Linear Z-Wave Garage Controller
Troubleshooting - Remote commands are not opening or closing the garage door attached to the Linear Z-Wave Garage Controller
There are multiple reasons why the Linear GD00Z might not be able to open or close the garage door using remote commands. As a general rule, the GD00Z device beeps/flashes any time it is attempting to open or close the garage door.
If it does not beep and flash, this could indicate Z-Wave communication issues or some other issue with the device. Follow the steps below to …
Garage Control - Device is Temporarily Disabled
The Device is temporarily disabled trouble condition indicates Alarm.com control has been temporarily disabled for the device, usually Garage Door control devices. This can occur when the device has failed multiple consecutive remote control attempts, has not successfully reported its status, or does not include an LED indicator as per UL requirements.
How to resolve:
This condition may require action from the user to restore the device’s status like manually opening or closing the device in …
myQ Garage control not appearing on Qolsys panel
Qolsys panel users who have already integrated myQ Liftmaster/Chamberlain garage control into their Alarm.com account can control the garage via the panel. myQ integration on the IQ Panel is automatic, sent by Alarm.com.
Sometimes this integration does not show on the panel after pairing myQ to Alarm.com, or after swapping the alarm panel on your Alarm.com account, such as swapping an IQ Panel 2 for an IQ Panel 4.
There are a few things to try/check to get garage control to show:
Ensure myQ…
Remove myQ controller from Alarm.com
While myQ Garage controllers are added to Alarm.com by the end user through the Alarm.com website (Settings > Manage Devices) at the time of this writing, only the Alarm.com service provider can remove the controller from the account.
If you have service through Surety and you need your myQ Controller removed, please submit a private message to us with your request. If you have more than one controller, please confirm the name of the controller as it appears in Alarm.com and we can get that tak…
