tyler
(Tyler)
January 8, 2024, 8:23pm
1
If your Wireless networking equipment or SSID has changed and you need to update your controller, steps on how to do so will vary by the device type in use.
Aladdin Connect by Genie and Over Head by OHD Anywhere through Alarm.com
Genie and Overhead Door - Integration Guide
Users can add Wi-Fi Genie and Overhead Door garage door openers to their Alarm.com systems and take full advantage of our smart automation and remote control features.
Requirements
Compatible mobile versions:
iOS device with firmware version 8.0+
Android device with firmware version 2.1+
Alarm.com mobile app version 4.10.4+
Current versions of the Aladdin Connect or OHD Anywhere mobile apps
Note: These apps are only required if integrating pre-in…
LiftMaster myQ 821LM , 821LMB , 821LMC-S , MyQ-G0301 , MyQ-G0401-ES
When your wireless settings or networking equipment change after a LiftMaster MyQ Hub (821LM, 821LMB, 821LMC-SCM, MyQ-G0301, MyQ-G0401-ES) or Wi-Fi Garage Door Opener is installed, the device will disconnect from the internet. This is because the device is still programmed with the old Wi-Fi information. New wireless information can be saved by clearing the device’s network memory and saving the new information.
Reconnect a disconnected garage door device
To reconnect a disconnected LiftMaster …
How to Clear Wi-Fi Settings on a myQ Wi-Fi Garage Door Opener
If you get a new router or change your wireless network name, password or security settings, you will need to clear the Wi-Fi settings on your hub or garage door opener and reconnect.
Erase the Wi-Fi Settings
Press and hold the black adjustment button between the arrows on the garage door opener until 3 beeps are heard. There is an initial beep, continue to hold the button approximately 6 seconds, during this time the up arrow will be flashing. The opener will beep an …
