Qolsys IQ Panel 2, IQ Panel 4 Device Programming PowerG
This guide covers some common programming choices for PowerG sensors wth the Qolsys IQ Panel 2/2+, IQ Panel 4 and IQ4 Hub alarm panels.
Below is the pathway taken at the panel to access sensor programming. We recommend manually programming the sensor. Installer code or Dealer code is required as the Master code does not give you access to panel programming.
To do so, tap Settings > Advanced Settings > enter installer code > Installation > Devices > Security Sensors.
Use the Add Sensor option and this will open the sensor configuration page. First set the Source field near the bottom right to PowerG. From there, enter the sensor’s 7-digit ID printed on the sensor (and on the box it comes in) in the appropriate field and program the remainder of the fields as desired.
  • PowerG sensors can be enrolled using the Auto Enroll Feature but each sensor has a different trigger for this (outlined below)
  • Using the QR code to auto learn the sensor using the Wizard is not currently recommended.
  • When manually programming, the sensor may report as “Not-Networked” indicating it has not communicated with the panel. This may resolve on its own but if not, you will need to tamper the sensor.
For a list of Sensor Group choices, please see this guide here.
PowerG Door/Window Contact or Recessed Door Contact - Programmed for an Entry Door
Sensor Type: Door/Window
Sensor Name: As Desired
Chime Type: As Desired
Sensor Group: 10-Entry-Exit-Normal-Delay
Voice Prompts: As Desired
Source: PowerG
PowerG DW Door/Window Contact - Programmed for a Window
Sensor Group: 13-Instant Perimeter D/W
Source: PowerG
Door Window Contacts - Auto Learn Trigger
PG7795 - Hold Enroll Button Down until flashing LED yellow
PG9945 - Add Battery during Auto Learn Mode, press SW3 button then let go
PG9303 - Add Battery during Auto Learn Mode
PG9307- Add Battery during Auto Learn Mode
PG9312 - Add Battery during Auto Learn Mode
PowerG Motion Detector
Sensor Type: Motion
Sensitivity Level: As Desired*
Sensor Group*: 17-Away-Instant-Motion
High Traffic Shutdown: As Desired*
Activation LED*: As Desired*
Source: PowerG
*: Setting may not be available with all PowerG motion types
Motion Sensor - Auto Learn Trigger
PG9984P: Press and hold the device enroll button until the LED lights steady
PG9924: Press and hold the device enroll button until the LED lights steady
PowerG Smoke and Heat Detector
Sensor Type: Smoke Detector
Sensor Group: 26-Smoke-Heat
Source: PowerG
Smoke Detector - Auto Learn Trigger
PG9936 - Add Battery during Auto Learn Mode
PowerG Wireless Temperature Sensor
Sensor Type: Temperature
Sensor Group: As Desired
Threshold Low: As Desired
Threshold High: As Desired
Source: PowerG
  • When using the PG9905 with Group 51, the High & Low threshold settings are set to 40°F and 100°F by default.
  • When using Group 52, the Low threshold setting is set to 40°F by default.
  • When using Group 53, the High threshold setting is set to 100°F by default. Thresholds can be customized between -22°F and 158°F.
Temperature Sensor - Auto Learn Trigger
PG9905 - Hold Enroll Button Down until flashing LED orange
PowerG Shock Sensor PG9935
Sensor Type: Door/Window-M
Sensitivity As Needed
Source: PowerG
Shock Detector - Auto Learn Trigger
PG9935 - Press and hold the device enroll button until the LED lights steady and then release the enroll button while the LED is
still lit.
PowerG Lock - IQ Panel 4 Only
Part Number: IQDLK-PGK-MB, IQDLK-PGK-SN, IQDLK-PGK-ORB
Auto-Learn - start with batteries removed from the lock.
To enroll, navigate to: Settings > Advanced Settings >Enter the Installer or Dealer Code > Installation > Devices >Automation > Auto Learn
With Auto learn selected, insert batteries in the lock and the device ID should populate on the panel screen.
Sensor ID: XXX-XXXX
Sensor Type: Door Lock
Pin Code (Optional): 8-digit above battery compartment of lock
Door Lock Volume: As Desired (On/Off)
Re-Lock Timer: As Desired (Disabled, 30 seconds, 60 seconds, 120 seconds, or 180 seconds)
PowerG Indoor Siren
Part Number: PG9901
Programming Selections
Sensor DL ID: XXX-XXXX
Sensor Type: Siren
Sensor Group: 33-Siren
Entry/Exit Beeps: On or Off
Siren Behavior: Siren and Strobe, Siren Only, or Strobe Only
Voice Prompts: On or Off
Sensor Chimes: On or Off
Chimes/Beeps Volume: Low, Medium, High
Source: PowerG
