PG9303 PowerG Wireless Door/Window Sensor
The PG9303 PowerG wireless door/window sensor is compatible with the IQ Panel 2+, the IQ Panel 4, or the IQ Panel 4 Hub containing a PowerG radio.
How to Program the PG9303
Steps to program the PG9303 into your panel are found in the topic below:
Specifications for the PG9303
Manufacturer DSC
Part number PG9303
Dimensions 2.6 x 1.2 x 0.4 inches
Wireless signal range 2000-2500ft in open air
Signals Alarm, alarm restore, tamper, tamper restore, low battery
Transmitter frequency USA: 912-919 MHz
Wireless protocol PowerG
Battery life 6 years (with typical use)
Operating Temperature -10°C to 55°C (32°F to 122°F)
Storage Temperature -40-80C
Battery 3V Lithium CR2450
How to install the PG9303
Physical installation of the PG9303 PowerG wireless door/window sensor should follow the manufacturer’s instructions found in the product installation manual. Installation steps from the PG9303 manual are below:
Installation Notes:
  • To comply with FCC and IC RF exposure compliance requirements, locate the device at a distance of at least 20 cm from all persons during normal operation. Do not co- locate the antennas used for this product, or operate them in conjunction with any other antenna or transmitter.
  • The PG9303 should be installed in non-hazardous indoor locations only.
  • For UL installations, use the screw installation method, as UL certified devices must be mechanically secured.
Mounting the PG9303: (Adhesive Installation)
  1. Peel the release liners off the two strips of double- sided adhesive tape and attach the tape to the back of the device and the magnet. See Figure 2-PG9303.
  2. Place the device on the frame of a window or door and place the magnet on the moving surface of the door or window itself, directed according to the location marks. See Figure 3-PG9303
  3. To ensure proper alignment so that the sensor can open and close properly, see Typical reed switch positions.
Mounting the PG9303 (screw installation)
  1. Insert a coin in the slot and twist to remove the cover. See image 1 of Figure 4-PG9303. If a coin is not available, insert a 4 mm flat screwdriver into each slot of the plastic cover and twist to open each side. See image 2 of Figure 4-PG9303.
  2. Screw the device base onto the door frame. See Figure 5-PG9303.
  3. Screw the magnet base on to the door, aligning it with the line on the device. See Figure 3-PG9303.
  4. To ensure proper alignment so that the sensor can open and close properly, see Typical reed switch positions.
  5. Clip the covers on to the device and magnet base. See Figure 7-PG9303)
The link for the full installation manual for the PG9303 is below:
Learn more about PowerG
