The DSC PowerG Recessed Door/Window Sensor PG9307 is compatible with all Qolsys brand IQ Panels with a PowerG radio, including the IQ Panel 4 IQP4001. It offers PowerG encrypted technology to protect wireless signal and can be hidden in the door or frame so it won’t affect your decor.
Sensor Specs
| Manufacturer | DSC |
| Part number | PG9307 |
| Dimensions | 2.66 inches x 0.75 inches |
| Wireless signal range | 2000-2500ft in open air |
| Signals | Alarm, alarm restore, tamper, tamper restore, low battery |
| Transmitter frequency | USA: 912-919 MHz |
| Wireless protocol | PowerG |
| Battery life | 10 years (with typical use) |
| Operating Temperature | -10°C to 55°C (32°F to 122°F) |
| Storage Temperature | -40-80C |
| Battery | 3V Lithium CR-2 |
| Low Battery Threshold | 2.5V |
How to Install the PG9307
Physical installation of the PG9307 recessed sensor should follow the manufacturer’s instructions found in the product installation manual. Installation steps from the PG9307 manual are below:
A link to the PG9307 full manual can be found here:
Mounting the PG9307
Sensor Installation
- Choose the installation location. This can be on the top of the door, or on the side of the door. Either in the frame or the door, depending on the material in use.
Install the sensor by the following steps: - Use a 3/4 drill bit to slowly drill a 3/4 inch hole for
the door/window contact in the door frame. - Fasten the contact housing to the mounting surface
with the two screws and insert the cover. If there
is no 3mm gap available between the door and the
frame, two step drilling is necessary. Using a
22mm tool, drill a 2mm shallow, followed by a
70mm deep hole with a 19mm tool. Break the slot
ears, clean the sharp edges and insert the device.
The device is recessed inside the frame, not interfering with the door.
Magnet Installation
Install the magnet by either of the following options:
By drilling:
a. Use a 3/4 inch drill bit to create a 15mm deep hole.
b. Peel off the double-sided tape on the magnet and stick it inside the magnet cover (part D). -
By using the double-sided tape without the magnet housing:
a. Peel off the double-sided tape on the magnet and stick it on the door/window
NOTE: Option 2 is possible only when there is a minimum gap of 2 mm between the door and the door frame.
Optional: Use a sticker on both the contact cover and the magnet cover to match the color of the door or the door frame
Programming thePG9307 with the Qolsys IQ Panel
- Place the IQ Panel into Auto-Learn Mode. To do so, at the panel navigate to:
- Settings
- Advanced Settings
- Enter your Installer or Dealer Code
- Installation
- Devices
- Security Sensor
- Auto Learn Sensor
With the panel in Auto-Learn Mode, open and close the door to trip the sensor.
Program the sensor as needed. Then Click Add to finalize programming.
Programming Instructions for Qolsys PowerG sensors like the PG9307 can be found here:
