2GIG-DW10-345 Thin Door/Window Contact, Programmed for an Entry Door
RF Sensor Type: (1) Entry Exit
RF Sensor Equipment Code: (0862) 2GIG Thin Door/Window Contact
RF Sensor Serial Number: Shift - Learn - Trip Sensor
RF Sensor Equipment Age: New
RF Sensor Loop Number: 2
RF Sensor Dialer Delay: Disabled
RF Sensor Voice Descriptor: As desired
RF Sensor Reports: Enabled
RF Sensor Supervised: Enabled
RF Sensor Chime: As desired, can be changed out of programming
The following video shows a walkthrough of adding this sensor to your alarm panel.
VIDEO
2GIG-DW10-345 Thin Door/Window Contact, Programmed for a Window
RF Sensor Type: (3) Perimeter
RF Sensor Voice Descriptor: As Desired
VIDEO
2GIG-DW10-345 Thin Door/Window Contact, Programmed for a Wired Input
RF Sensor Type: Chosen Based on Wired Sensor Type
RF Sensor Loop Number: 1
The following video shows an example of a sensor using the wired input.
VIDEO
2GIG-DW20R-345 Recessed Door Contact
RF Sensor Equipment Code: (0863) 2GIG Recessed Door Contact
VIDEO
2GIG-PIR1-345 Motion Detector
RF Sensor Type: (4) Interior Follower
RF Sensor Equipment Type: (2) Motion
RF Sensor Equipment Code: (0869) 2GIG PIR With Pet Immunity
RF Sensor Chime: Disabled
VIDEO
2GIG-GB1-345 Glass Break Detector
RF Sensor Equipment Type: (1) Contact
RF Sensor Equipment Code: (0864) 2GIG Glass Break Detector
VIDEO
2GIG-SMKT3-345 Smoke/Heat/Freeze Detector , 2GIG-SMKT8-345 Smoke/Heat/Freeze Detector
Smoke:
RF Sensor Type: (9) 24 Hour Fire
RF Sensor Equipment Code: (1058) 2GIG Smoke Detector
RF Sensor Serial Number: Shift - Learn - Tamper Sensor
RF Sensor Voice Descriptor: Smoke Detector
Heat:
RF Sensor Voice Descriptor: Heat Detector
Freeze:
RF Sensor Type: (8) 24 Hour Auxiliary
RF Sensor Equipment Type: (6) Freeze
RF Sensor Loop Number: 3
RF Sensor Voice Descriptor: Freeze Detector
VIDEO
2GIG-CO3-345 Carbon Monoxide Detector
RF Sensor Type: (14) 24 Hour Carbon Monoxide
RF Sensor Equipment Code: (1026) 2GIG CO Detector
VIDEO
ECFF345 2GIG Compatible Firefighter
RF Sensor Equipment Code: (0616) Existing Smoke Detector
VIDEO
jwcsurety
(Jason)
February 8, 2017, 3:25pm
10
2GIG-IMAGE1 Alarm.com Image Sensor
RF Sensor Equipment Code: (9999) Alarm.com Image Sensor
RF Sensor Serial Number: Learn - Insert Batteries or Reset Sensor
VIDEO
jwcsurety
(Jason)
February 8, 2017, 3:26pm
11
2GIG-KEY2-345 Four Button Keyfob
Fob Used: (1) Enabled
Fob Equipment Code: (0866) Key2-345 4-Button Keyfob Remote
Fob Serial Number: Shift - Learn - Press Button
Fob Equipment Age: New
Fob Emergency Key: As Desired
Fob Key 2 Can Disarm: As Desired, (1) Enabled recommended
Fob Voice Descriptor: As Desired
Fob Arm No Delay: As Desired, Delay refers to Entry Delay
Fob Key 4 Output: (0) Disabled, unless used
The following video shows a walkthrough of adding this device to your alarm panel.
VIDEO
tyler
(Tyler)
March 15, 2021, 1:56pm
13
2GIG-FT6-345 Water Leak Detector
For the water detection zone:
RF Sensor Type: 08 – 24 Hour Auxiliary Alarm
Equipment Type: Water
Equipment Code: (1065) 2GIG Flood Sensor
Serial Number: Learn – Pull Battery tab or activate sensor to signal to panel.
Equipment Age: New
Sensor Loop: 3
Optionally you can then add the other temp zones:
Heat
Equipment Type: Temperature
Serial Number: Same number as water zone
Equipment Age: New
Sensor Loop: 2
Freeze
Equipment Type: Freeze
Equipment Age: New
Sensor Loop: 1
tyler
(Tyler)
December 19, 2022, 5:24pm
15
2GIG PAD1-345 Wireless Keypad
To begin programming, Click on the panel logo and enter your installer code ( default 1561) > System Configuration > Keypads. Select an available slot, click “Edit Keypad”.
Keypad Used: “Enabled” This will need to be enabled to use the keypad.
Equipment Code: “0867 - PAD1-345 Wireless Keypad” Select this equipment code for this device.
Serial Number: The serial number for the keypad can be manually entered or learned into the system.
To learn-in the keypad, click the “Learn” button.
Then hold down one of the panic buttons on the PAD1 keypad until its serial number appears on the screen. If unsuccessful, release the button and try again. Once the serial number is populated, be sure that it is correct, then press “Accept”.
Equipment Age Select “New”
Emergency Keys- If enabled, panic keys will be enabled.
Voice Descriptor - As desired
Confirm the changes. Click “Return to System Configuration” in the top-right corner of the screen, then click the back arrow on the left side of the screen. Click “Save. ”
Be sure to test the keypad by entering a user code and then pressing the “Stay” or “Away” button.
When testing, you may want to place your monitoring account on test mode to avoid false alarms. If you are a Surety subscriber, you can do this via the Test My System tab in the System Manager section of your Surety account.
tyler
(Tyler)
July 19, 2023, 4:17pm
16
Wireless Tilt Sensor 2GIG-TILT1-345
Programming
Sensor Types: (01) Exit/Entry 1 or (03) Perimeter
Equipment Code: Legacy: (1062) 2GIG Tilt Sensor. eSeries: (2061) eSeries Tilt Sensor
Serial Number : TXID
Loop Number(s): Loop 1
Voice Descriptor : As desired
Sensor Reports : Enabled
Sensor Supervised : Enabled
Sensor Chime : As desired
tyler
(Tyler)
June 25, 2024, 1:44pm
17
Remove a sensor from programming
Sometimes you need to clear out an old sensor that is no longer being used. To do so:
Navigate to the Installer Toolbox and do the following.
Click on system configuration.
Press the right arrow until you get to the sensor you want to remove.
Press the down arrow once to get the Q: Select RF Sensor 1 type
Press the left arrow until the sensor has been changed to unused .
Press the down arrow to get to Q: Enter RF Sensor 1 Serial Number
Replace the current number with 7 zeroes. This will disassociate the RF Sensor ID
Press Next > Skip > End .
Make sure the box marked “Save Changes” is checked.
Press exit .
