Qolsys IQ Panel 2 Sensor Programming
This guide covers some common programming choices for the Qolsys IQ Panel 2 and 2+ alarm panels.
Below is the pathway taken at the panel to access sensor programming. We recommend choosing the Auto Learn Sensor feature.
After choosing Auto Learn Sensor, the panel will begin to listen for the sensor’s signal. It is at this point that you would tamper or trip the sensor to initiate the pairing process.
For a list of Sensor Group choices, please see this guide here.
Qolsys DW Door/Window Contact or Recessed Door Contact - Programmed for an Entry Door
Sensor Type: Door/Window
Sensor Name: As Desired
Chime Type: As Desired
Sensor Group: 10-Entry-Exit-Normal-Delay
Voice Prompts: As Desired
*S-Line should be selected if sensor is S-Line, Security RF319.5MHz.
Qolsys DW Door/Window Contact - Programmed for a Window
Sensor Group: 13-Instant Perimeter D/W
Qolsys S-Line PIR Motion Detector
Sensor Type: Motion
Sensor Group: 17-Away-Instant-Motion
Qolsys IQ Smoke Detector
Sensor Type: Smoke Detector
Sensor Group: 26-Smoke-Heat
*S-Line should be selected if sensor is S-Line, otherwise Security RF319.5MHz.
Qolsys IQ Carbon
Sensor Type: CO Detector
Sensor Group: 34-CO
Qolsys IQ Glassbreak
Sensor Type: Glass Break
Sensor Group: 13-Glass Break
Qolsys IQ Flood or other Multi-function Flood Sensor - Flood Generates an Alarm State
Sensor Type: Water
Sub Type: IQ Flood
Sensor Group: 38-Water Sensor
Qolsys IQ Flood or other Multifunction Flood Sensor - Local Alert Only
Sensor Type: Water
Sub Type: IQ Flood
Sensor Group: 25-Water Non Reporting
  • For all non Qolsys/Multifunction Flood sensors, when selecting Type: Water, choose Sub-Type: Other Flood
