Malfunction Sensors Brand Spank’n new
Hi Tyler. Where is this info located for the IQ-4 panel that in advanced setting I can enter 1111 for the installer code?
Qolsys does not provide a manual or a how to guide specifically in the box but we have the manual located on the product page and can be found here.
While in the Installer code section of the advanced settings I noticed that I could check for system updates through the WiFi connection. Well I found the panel needed to be updated to the latest firmware which I could not do using the regular pass code that gets me into advanced settings and shuts the alarm on-off, etc.
Firmware updates can be done that way if the firmware file is available.
Typically you will need the Installer Code (default 1111) or Dealer Code( defualt 2222) to make most programming changes.
If you attempted to update software prior to connecting the panel to service, it wont work, the panel needs to be communicating with Alarm.com first.
Firmware patch notes and update steps can be found on thie forum post here. You may want to follow that so you dont miss out firmware updates. Some updates cannot be done automatically and require a patch tag.
One thing I would like to mention is that some of the sensors on the first try when adding I simply used the QR code located on each box (I wrote the name of each location on the box), scanned using the IQ-4 camera and added to the sensor.
While this method works, I would always recommend using Auto Learn Mode and tripping/tampering the sensor to learn it in. You can do this before mounting the sensor. It allows you to test functionality before mounting and allows you to confirm that the unique TXID on the sensor matches what gets learned into the panel.
We have a lot of How To Guides on the forum that cover a variety of topics. The following may be of use to you:
Programming 319.5Mhz sensors
Programming Z-Wave Devices (and tips for creating a good Z-Wave Network)
Video
