tyler
(Tyler)
March 5, 2025, 5:36pm
1
Hello! Welcome to my home. The front door is where the action is. Keep an eye on who's there, detect people, and answer remotely. Features: Doorbell rings through to your phone, no matter where you are Answer with two-way audio or just look and...
Price: $182.00
The ADC-VDB755P is Alarm.com’s first doorbell camera with Power over Ethernet (PoE) capabilities, allowing for a reliable network connection and power supply.
This doorbell offers crystal clear 2MP picture and an expansive 150° horizontal and 150° vertical Field of View so customers can see and do more at the front door.
Alarm.com’s powerful People Detection and crisp Two-Way Audio help reduce false notifications while bringing increased awareness and allowing users to communicate with visitors.
With support for SVR Recording your customers can locally record encrypted video and view footage from anywhere. Plus - a wide range of operating temperatures increases install flexibility, making this a great choice in any environment.
Features
Power over Ethernet
Expansive 150° horizontal and 150° vertical Field of View ensures customers get a full picture of what’s happening at their front door
Video Analytics with rapid People Detection for faster, more relevant alerts and fewer false notifications
Full HD resolution, High Dynamic Range (HDR), and infrared night vision
Two-Way Audio
Compatible with the Alarm.com Smart Chime (W115C)
2MP live video and saved clip viewing via the Customer app and Customer website
Compatible with the Alarm.com CSVRs and SVR210 for continuous recording
No power module required for compatibility with mechanical or digital chimes
Included accessories
ADC-VDB755P Video Door Station
Wall anchors (x2) & screws (x2)
Requirements
Power
Ethernet connection
PoE 802.3af
10/100Mbps RJ-45
Specifications
Recording compression
H.264
Max resolution
1440 x 1440
Lens/angle of view
150° horizontal, 150° vertical
Low-light sensitivity
0 lux with IR
IR range
Up to 15 feet (5 meters)
Image adjustments
Flip, brightness, contrast, saturation, sharpness, exposure
Wireless connectivity
N/A
Operating temperature
-58°F - 122°F (-50°C - 50°C)
Operating humidity
< 95% (non-condensing) RH
Dimensions (W x L x D)
2.45 x 4.50 x 1.54 (62.3 x 114.2 x 39.1mm)
Activity Detection
Advanced Video Analytics for People Detection
Audio
Two-Way Audio (Full Duplex)
Compliance
FCC, IC, RCM, CE Class B, UL, RoHS, WEEE, Compliant with Section 889 of the NDAA*
Status light guide
LED pattern
Description
Off
Power off
Blinking yellow
Camera power cycling
Solid red
No local or internet connection
Blinking red
Power on, camera booting
Blinking green
Local network connection
Solid green
Connected to Alarm.com
Alternating red and green
Camera resetting to factory default (press and hold button for 45-50s)
Alternating yellow and white
Change the chime type to mechanical (press and hold button for 60-65s) If the chime type is set to digital or none
Alternating blue and white
Change the chime type to digital (press and hold button for 60-65s) If the chime type is set to mechanical
Installation Guides
How To Install the Alarm.com PoE Video Door Station ADC-VDB755P
Pre-installation checklist
ADC-VDB755P video doorbell.
Video Analytics service package and the Doorbell Cameras add-on
For Surety Customers, you will need:
Surety Complete plan
Surety Protect plan
Surety Alarm/Home with Surety Video add-on
Ethernet connection to PoE (802.3af) power supply and internet access.
(Optional) A Wired compatible mechanical or digital chime and wired doorbell transformer.
In the box
Installation card wi…
How To Wire the ADC-VDB755P to a Chime
The Alarm.com PoE Video Doorbell (ADC-VDB755P) is wired in the same configuration for both mechanical and digital chimes for ease of installation.
Important: The transformer must be rated for the chime in use.
Working doorbell check
First, verify that the existing wired doorbell is working and that it is wired properly. If the existing doorbell does not ring the indoor chime when the button is pressed, there is a power issue. This must be addressed before beginning the Alarm.com Video Doorbell…
User Guides
How To Adjust saved video resolution for the ADC-VDB755P
Saved video settings can be customized for the ADC-VDB755P.
To adjust saved video image settings using the Alarm.com website:
Log into the Alarm.com website.
Click Video.
Click Settings.
Using the Video Device dropdown menu, select the desired camera.
Click Saved Video.
Using the Resolution (pixels) dropdown menu, select the desired video resolution.
Click Save.
How To Factory reset an ADC-VDB755P to its default settings
Resetting a video device to its factory defaults removes all programming from the device.
Important: Wait at least two minutes for the video device to power on fully before performing the following procedure. The factory reset might fail if the device is still powering on.
Reset procedure
Reset button location
1. Press and hold the doorbell button for at least 45-50 seconds until the LED starts blinking red and green.
The doorbell button on the front of the ADC-VDB755P.
2. Wait for t…
How To Adjust the chime type for the ADC-VDB755P
Configure the ADC-VDB755P chime type to match the chime connected to the device. There is an option to select no chime.
To adjust the chime type using the doorbell button:
To adjust the chime type using the Alarm.com website:
To adjust the chime type using the Alarm.com mobile app:
Frequently Asked Questions
Are there additional mounting brackets for the ADC-VDB755P?
Yes. Additional mounting brackets for the ADC-VDB755P include the Single-gang Mounting Plate Kit (ADC-VDBA-755P-MNT) and the Wedge Mount Kit (ADC-VDBA-755P-WMK) that includes two additional wedge types.
The additional wedges allow you to achieve more extreme left/right pans for installation on walls perpendicular to the door. It also adds different options for tilt combined with left/right pan to allow for expanded vFoV to the ground, minimizing the blind spot at the bottom of the field of view…
What types of chimes are compatible with the ADC-VDB755P?
The VDB755P is compatible with standard mechanical and digital chimes.
Note: Because the ADC-VDB755P does not draw power from the doorbell chime circuit and transformer, it may be able to operate chimes outside the standard types listed here, similar to an analog doorbell button.
However, Alarm.com cannot test every doorbell chime available to users and, therefore, cannot guarantee or support performance on all chime types.
Compatible chimes
Alarm.com Smart Chime (ADC-W115C)
The ADC-W115C an…
Troubleshooting Guides
The ADC-VDB755P detects too much or too little motion
You can configure the ADC-VDB755P’s motion detection settings to only capture what is important. Follow these guidelines to optimize motion detection.
Adjust the sensitivity of the Video Analytics rule
To adjust the sensitivity using the Alarm.com website:
To adjust the sensitivity using the Alarm.com mobile app:
Verify the Ground Zone is configured correctly
Avoid overlapping ground zones with objects that are prone to movement (e.g., such as trees, bushes, or other objects that move in t…
The Alarm.com PoE Video Door Station (ADC-VDB755P) is constantly buzzing or humming
The Alarm.com PoE Video Door Station (ADC-VDB755P) does not make a humming or buzzing sound, but the chime can. On a small number of installations, mechanical chimes can buzz or hum, indicating the current is running through the chime when the button is not pressed.
An incorrectly configured VDB755P or a transformer that is too old can cause a buzzing door chime. The VDB755P’s configuration requirements change based on what type of door chime is on the circuit.
Verify the chime power requireme…
The indoor chime does not make sound when a guest rings the ADC-VDB755P
If the ADC-VDB755P is not ringing the indoor chime when triggered, use the following steps to troubleshoot the behavior.
Verify the original chime and doorbell button function properly
Reconnect the original doorbell to the chime to test.
Verify the installation meets the power and wiring requirements
Power and Ethernet requirements
Power
PoE 802.3af
Ethernet connection
10/100Mbps RJ-45
Wiring the VDB755P
Check the wiring
Verify the correct Chime Type is selected
Adjust the ch…
Unable to hear audio during an ADC-VDB755P doorbell call
There are several possible reasons why audio issues may be experienced during a call between the Customer website and the ADC-VDB755P.
If unable to hear audio from the Alarm.com mobile app
Verify the app settings and permissions
Verify the app is updated to the most recent version.
In Video Device Info, verify that the Call Volume slider is all the way to the right.
To adjust the Call Volume using the Alarm.com website:
To adjust the Call Volume using the Alarm.com mobile app:
### Verify…
