You can configure the ADC-VDB755P’s motion detection settings to only capture what is important. Follow these guidelines to optimize motion detection.
Adjust the sensitivity of the Video Analytics rule
To adjust the sensitivity using the Alarm.com website:
1. Log into the Alarm.com website.
2. Tap **Video**.
3. Tap **Settings Gear Icon**.
4. Tap **Recording Rules**.
5. Tap **Edit Pencil**on the desired rule.
6. Using the *Sensitivity* slider, adjust the sensitivity up to increase the sensitivity or down to decrease the sensitivity.
7. Tap **Save**.
To adjust the sensitivity using the Alarm.com mobile app:
1. Log into the Alarm.com mobile app.
2. Click **Video**.
3. Click **Recording Rules**.
4. Click **Edit** on the desired rule.
5. Using the *Sensitivity* slider, adjust the sensitivity up to increase the sensitivity or down to decrease the sensitivity.
6. Click **Save**.
Verify the Ground Zone is configured correctly
- Avoid overlapping ground zones with objects that are prone to movement (e.g., such as trees, bushes, or other objects that move in the wind).
- Only draw the rule where the feet of the person should enter.
- Do not increase the size of the Ground Zone to cover the whole of the person.
- Do not include walls, trees, or other structures in the rule/selection.
- After observing what the rule detects over a few days, consider adjusting the Detection Sensitivity slider higher for more triggers or lower for fewer.
