What types of chimes are compatible with the ADC-VDB755P?
The VDB755P is compatible with standard mechanical and digital chimes.
Note: Because the ADC-VDB755P does not draw power from the doorbell chime circuit and transformer, it may be able to operate chimes outside the standard types listed here, similar to an analog doorbell button.
However, Alarm.com cannot test every doorbell chime available to users and, therefore, cannot guarantee or support performance on all chime types.
Compatible chimes
Alarm.com Smart Chime (ADC-W115C)
  • The ADC-W115C and doorbell camera are powered independently
  • Chime settings are controlled through the account
Mechanical chimes
  • Standard Front/Trans/Rear leads
  • Physical striker pins
Digital chimes
  • A speaker in the chime instead of physical striker pins
Incompatible chime types
Tube chimes
  • Look for tubes attached to the chime that resemble a pipe organ’s tubes.
Intercom systems
  • Intercom systems typically have large speakers and a complicated wiring scheme as shown in the following image.
  • Look for standard Front/Trans/Rear leads. If there are extra leads, it may indicate the chime is an intercom system.
