Alarm.com Wi-Fi Doorbell Camera and Slim Line
Overview
With two options to choose from – the original Alarm.com Wi-Fi Doorbell Camera and the new Slim Line – you can have a variety of options for front door awareness that can be added to your Alarm.com system.
Features
- Doorbell with integrated camera
- PIR motion sensor
- Digital microphone and speaker
- Record doorbell-triggered clips
- Set motion-triggered automation rules
- Receive real-time alerts
Included materials:
- Wall mounting bracket
- Wall screws
- Masonry anchors
| Specifications | |
| Wi-Fi | Compatible with Wi-Fi 802.11 b/g/n, 2.4 GHz up to 150 Mbps. |
| Video Camera | 180° view, auto-scaling, full-color |
| Resolution | Live: 1080p (can be lowered) Recorded: 720p |
| Night Vision | Full Color |
| Audio | Omni-directional microphone |
| Motion Sensor | Detects motion up to 8 ft range |
| Battery Life | 3 to 5 years |
| Dimensions | (width x depth; weight): 2.8 x 0.9 in (7.1 x 2.2 cm); 1.9 oz (53.8g) |
| Environment | Outdoor use, operating temp -40°F/-40°C to 140°F/60°C, water resistant, 0-100% condensing |
Power: Operational range is 8-36VAC, 10VA or 12VDC 0.5 to 1.0A wired to an in-home mechanical or digital doorbell chime. Digital doorbell chime compatibility requires SkyBell Digital Doorbell Adapter - not included.
Alarm.com recommends a minimum of 12 VAC for consistent functionality, but the recommended range for best results is 16-24 VAC.
Network requirements Minimum bandwidth 2MBPS
Alarm.com Slim Line Doorbell Camera (ADC VDB105 and VDB106)
| Specifications | |
| Resolution | Live: 720p (can be lowered) Recorded: 720p |
| Night Vision | Infrared |
| Dimensions | (width x depth; weight): 1.4 x 4.8 x 1.1 in (3.65 x 12.2 x 2.86 cm); 2.0 oz (56.7 g) |
Power: Power
Operational range is 8-36VAC, 10VA or 12VDC 0.5 to 1.0A wired to an in-home mechanical or digital doorbell chime. Digital doorbell chime compatibility requires SkyBell Digital Doorbell Adapter - not included.Alarm.com recommends a minimum of 12 VAC for consistent functionality, but the recommended range for best results is 16-24 VAC.
