SkyBell Doorbell Camera - LED and Reference Guide
SkyBell HD Wi-Fi Doorbell Camera VDB101 / VDB102 LED and troubleshooting reference guide
Normal operation
LED pattern Description Details
Green solid V2.png Ready and working normally Use the Customer Website or Customer app to choose a custom color in place of default green.
White solid V2.png In Call mode A call has been initiated (i.e., the doorbell button was pressed or the doorbell detected motion) or is occurring.
Yellow solid V2.png Starting up Please wait while the doorbell is booting up.
Red blue alternating blink V2.png Battery is charging Battery may charge for ~30 minutes after installation.
Blue green alternating blink V2.png Connected to Wi-Fi, waiting for server connection Please wait.
Blue yellow alternating blink V2.png Firmware update in progress Please wait.
Requires attention
Orange rapid double blink V2.png No Wi-Fi connectivity Check your Internet connection. Your Wi-Fi credentials may have changed. Enter Wi-Fi Access Point Mode and re-add the doorbell camera using the Customer app.
Red rapid double blink V2.png Power supply issue . The doorbell transformer may need to be replaced.
Troubleshooting
Press and hold doorbell button for the time shown to perform a troubleshooting step.
Note : If the LED on the doorbell is not showing any color, there may be a power issue or it may have been turned off in the Video Settings on the Customer Website.
Green blinking V2.png Entering Troubleshooting modes Continue to press & hold for troubleshooting steps below.
Red green alternating blink V2.png Wi-Fi Access Point mode Connect to the camera’s temporary networkand use the Customer app to re-add the camera.
Blue blinking V2.png Power cycle Reboots the camera. Push & hold ~70 sec until flashing, then release.
Yellow blinking V2.png Factory reset Factory resets the camera. Deletes all Wi-Fi and configuration information.Push & hold ~80 sec until flashing, then release.
Slim Line Wi-Fi Doorbell Camera VDB105/106 VDB105x/106x LED and troubleshooting reference guide
LED pattern key
Normal operation
Solid green
LED solid green.svg Ready and working normally Use the Customer Website or Customer app to choose a custom color in place of default green.
Solid white
LED solid white.svg In Call mode A call has been initiated (i.e., the doorbell button was pressed or the doorbell detected motion) or is occurring.
Solid blue
LED solid blue.svg Starting up Please wait while the doorbell is booting up.
Pulsing blue
LED pulsing blue.svg Battery is charging Battery may charge for ~30 minutes after installation.
Blinking blue and green
LED alternating blue green.svg Connected to Wi-Fi, waiting for server connection Please wait.
Blinking blue and amber
LED alternating blue amber.svg Firmware update in progress Please wait.
Note : Once the outside temperature reaches roughly -10 degrees Fahrenheit, the doorbell camera rings the chime quickly twice in a row.
Requires attention
Double-blinking orange
LED double-blinking orange.svg No Wi-Fi connectivity Check your Internet connection. Your Wi-Fi credentials may have changed. Enter Wi-Fi Access Point Mode and re-add the doorbell camera using the Customer app.
Double-blinking blue
LED double-blinking blue.svg Power supply issue Contact your installer.
The doorbell transformer may need to be replaced|
Troubleshooting
Blinking green
LED blinking green.svg Entering Troubleshooting modes Continue to press & hold for troubleshooting steps below.
Blinking red and green
LED alternating red green.svg Push & hold ~60 sec until flashing, then release. Wi-Fi Access Point mode Connect to the camera’s temporary network
Blinking blueLED blinking blue.svg
Push & hold ~70 sec until flashing, then release. Power cycle Reboots the camera.
Blinking amberLED blinking amber.svg
Push & hold ~80 sec until flashing, then release. Factory reset
