Alarm.com Video Doorbell (ADC-VDB770)
Overview
The ADC-VDB770, Alarm.com’s next-generation video doorbell camera has an expansive 150° vertical Field of View (FOV), allowing you to monitor the entire doorway area. Two-Way Audio and full portrait viewing in the app make it easier than ever to see a speak with visitors. Plus, the ADC-VDB770 uses video analytics to minimize false-positive motion detection and to enable rapid detection of people, so you receive alerts even if visitors don’t ring the bell.
Features
- Expansive FOV (150° V, 115° H)
- Full HD (1440 x 1920) video resolution
- High dynamic range (HDR)
- IR night vision
- Video Analytics for faster, more relevant alerts
- Live video and saved clip viewing
- Two-Way Audio through the mobile app
- Battery heater for low-temperature operation
- 2x2 antenna for improved Wi-Fi range
- Compatible with existing doorbell transformers (requires 16-30 VAC, 10 VA)
- Compatible with mechanical and digital chimes
Included accessories
- Angled mounting wedges
- Power module
- Mounting brackets
- Wire connectors
- Wire extenders
| Specifications | |
| Recording Compression | H.264 |
| Ingress protection | IPX4 |
| Max Resolution | 1440 x 1920 |
| Image sensor | 1/2.7" CMOS, 5 MP, 1440 X 1920 |
| Lens/angle of view | 150° vertical, 115° horizontal |
| Low-light sensitivity | 0 lux with IR |
| IR range | Up to 15 feet (5 meters) |
| Image adjustments | Flip, brightness, contrast, saturation, sharpness, exposure |
| Wireless connectivity | 802.11 b/g/n, 2.4 GHz |
| Operating temperature | -22° F to 104° F (-30°C to 40°C) |
| Operating humidity | < 95% (noncondensing) RH |
| Dimensions (W x L x D) | (W x L x D) 1.7" x 5"x 1.5" (42 x 127 x 38 mm) |
| Motion sensor | None (Video Analytics used for motion detection) |
Power requirements
AC transformer 16-30V AC, 10-30VA*
DC transformer 15-30V DC, 8W minimum*
The power module included with the ADC-VDB770 is required for every installation
