tyler
(Tyler)
January 9, 2024, 8:21pm
1
Alarm.com is compatible with a variety of smart thermostats that allow you to monitor and control your HVAC system via the Alarm.com website and mobile app.
Compatible Devices
Alarm.com ADC-T2000
Alarm.com ADC-T3000
Alarm.com ADC-T40K-HD
Service Plan Needed
A service plan with Home Automation control through Surety would be required to use thermostats remotely through Alarm.com. Those plans include:
Surety Home
Surety Complete
tyler
(Tyler)
January 9, 2024, 8:29pm
4
General Questions
Which types of HVAC systems is the Alarm.com Smart Thermostat compatible with?
Which systems are compatible with the Alarm.com Smart Thermostat?
The Alarm.com Smart Thermostat is compatible with both heat pump systems and conventional (normal) systems.
Examples of heat pump systems include:
Air source heat pump
Geothermal heat pump
Examples of conventional (normal) systems include:
Furnaces
Boilers
Steam and hot water radiators
Radiant (in-floor heating)
Does the Alarm.com Smart Thermostat support multistage systems?
Yes. The Alarm.com Smart Thermostat is compatible w…
What Z-Wave thermostat features are available with Alarm.com?
The following table compares which Z-Wave thermostat features are available on the Alarm.com Website versus the Alarm.com mobile app.
Features
Website compatibility
Mobile App compatibility
View/change current thermostat mode and set point
Compatible
Compatible
Configure automated thermostat schedules
Compatible
Compatible
Configure thermostat rules (i.e., Extreme Temperature Energy Savings, Sensor Left Open Energy Saver, Smart Away, Fire Safety)
Compatible
Incompatible
Configure thermostat notifications (i.e., Temperature threshold, Humidity, Thermostat changes)
Compatible
Compatible
Fan control
Compatible
Compatible
How to Add/Remove Smart Thermostat from Z-Wave Network
The Smart Thermostats from Alarm.com are Z-Wave devices. Below are steps for each device including Clearing the device (deleting), Adding the device (Pairing), and running a Z-Wave Network Rediscovery.
ADC-T2000
ADC-T3000
ADC-T40K-HD
More information on how to set up a Z-Wave Network correctly can be found here:
What are the differences between the various Alarm.com Thermostats?
There are various differences between the ADC-T2000, ADC-T3000, and ADC-T40K-HD Smart Thermostats including the design, compatible features, user settings, and advanced settings.
Feature
ADC-T2000
ADC-T3000
ADC-T40K-HD
Battery-Powered Option
Extended Battery Life
Alarm.com Places
Extreme Temps
Scenes
Schedules
Temp Presets
HVAC Analytics
Energy Star-certified
N/A
Works with Alarm.com Temperature Sensor
Remote …
How to find the Firmware Version of the Alarm.com Smart Thermostat
The firmware of an Alarm.com Smart Thermostat can be found locally on the thermostat or on the box.
Note: To update the firmware of an Alarm.com Smart Thermostat, it must be replaced with a new one at this time.
To find the firmware locally on the thermostat:
Smart Thermostat HD ADC-T40K-HD
Tap the display to wake up the thermostat.
Tap Menu.
In Menu, tap About.
The firmware information will be listed in the About screen.
ADC-T3000
Press the MINUS button.
Select ABOUT.
Select VERSION.
Whe…
Smart Humidity Control
View current humidity level
Alarm.com users with a Smart Thermostat and compatible panel can see their current humidity level by clicking on the thermostat card on the Alarm.com Website or mobile app.
The ADC-T40K-HD will display the humidity level on the thermostat’s display by default. The ADC-T3000 can display the humidity percentage locally in all modes when the Display Option is set to Humidity and the temperature is set to Fahrenheit. Humidity display is not supported when in Celsius mod…
Alarm.com Remote Temperature Sensors
Temperature Sensors on the Thermostat page
By default, the HVAC system keeps the thermostat’s internal thermometer at a selected target temperature. With Temperature Sensors placed in different rooms around the home, the system is also able to detect the temperature in these other areas, such as an upstairs bedroom or downstairs den.
View Temperature Sensors
[tempsensor]
Note : If the thermostat is in Off mode, the Thermometer Icon (noted in the above image) does not display.
Direct Control:…
Automatic Shutoff during Smoke, Fire, or CO Alarm
In the event of a smoke, fire, or carbon monoxide alarm on the security system, Alarm.com automatically turns the Alarm.com-connected thermostats to OFF mode, including the fan, to prevent the circulation of smoke and poisonous gas. This is a default and highly recommended setting for all Alarm.com systems with a thermostat attached, but it can be disabled or re-enabled on the customer website using the following steps.
Compatibility
In general all of the Alarm.com thermostats (ADC T2000, T3000…
