The firmware of an Alarm.com Smart Thermostat can be found locally on the thermostat or on the box.
Note: To update the firmware of an Alarm.com Smart Thermostat, it must be replaced with a new one at this time.
To find the firmware locally on the thermostat:
Smart Thermostat HD ADC-T40K-HD
- Tap the display to wake up the thermostat.
- Tap Menu.
- In Menu, tap About.
- The firmware information will be listed in the About screen.
ADC-T3000
- Press the MINUS button.
- Select ABOUT.
- Select VERSION.
When looking for the general firmware of the thermostat, refer to the MFW version.
ADC-T2000
- Put the thermostat into OFF mode.
- Press and hold the UP button until the display changes from the temperature to a version number (e.g., 1.30, 1.50, 1.60, etc.)
- Press the UP button again to cycle to the version number indicated with the HEAT / COOL icons.
Caution : The version indicated with the RADIO ICON is not the firmware of the thermostat.
To find the firmware on the box:
The box the thermostat came in will indicate the thermostat version that was flashed at the factory. It is labeled as FWV.
