tyler
(Tyler)
January 11, 2024, 8:40pm
1
The Smart Thermostats from Alarm.com are Z-Wave devices. Below are steps for each device including Clearing the device (deleting), Adding the device (Pairing), and running a Z-Wave Network Rediscovery.
ADC-T2000
This guide covers how to get an Alarm.com Smart Thermostat ADC-T2000 into Z-Wave inclusion mode.
If you are looking for how to pair the Alarm.com T3000, see this guide here .
Should you need to know how to put your panel into Z-Wave pairing mode, you can find panel specific information below:
2GIG Go!Control, GC2
2GIG GC3
Qolsys IQ Panel 2/2+
ADC T2000
[ADCT2000]
Connect the ADC T2000 thermostat to the system
Put the thermostat in OFF mode (i.e. no mode icons are lit).
Put the Z-Wave c…
ADC-T3000
This guide covers how to get an Alarm.com Smart Thermostat ADC-T3000 into Z-Wave inclusion mode.
If you are looking for how to pair the Alarm.com T2000, see this guide here .
2GIG GC3
ADC T3000
[ADCT3000]
Add to the Z-Wave network
Put the Z-Wave controller into ADD mode. Refer to the controller documentation for more information.
ADC-T40K-HD
Add the Smart Thermostat HD from a Z-Wave network
Place the Z-Wave controller into Add Mode.
Tap MENU on the Display.
Tap Network Settings.
Tap Z-Wave Connection.
Tap Add to Network.
In Network Configuration, tap Add.
Note: The Add button is only displayed if the Smart Thermostat HD is not currently enrolled to a Z-Wave network.
A message will appear to indicate whether the device was enrolled.
Delete the Smart Thermostat HD from a Z-Wave network
Place the Z-Wave controller into Delete Mod…
More information on how to set up a Z-Wave Network correctly can be found here:
This guide is a reference on how to pair z-wave devices to your Z-wave compatible alarm panel.
If you would like to increase your current Z-Wave mesh network range and quality, see this post here.
One of the biggest rewards of owning an alarm system and utilizing Alarm.com is the ability to create your own smart-home network of Z-wave devices.
There is, however, a slight learning curve to the installation and troubleshooting when it comes to Z-Wave. Required steps unique to Z-wave (as oppos…
