How To Tell if your Cellular Module is 3G or 4G LTE
As of June 2019 all new service through Alarm.com requires an unregistered 4G LTE cellular module due to the impending 3G sunset (2022).
In order to sign up for new service through Surety, your alarm system will need to have this 4G LTE module installed.
This is guide should help you identify which module you have currently and how to upgrade to 4G LTE.
You can input your existing 15-digit cellular module number into this tool here to determine if your module is eligible for service through Surety.
2GIG Panels
With 2GIG brand panels you’re going to find a few different panel types, either the 2GIG Go!Control, GC2/2e or the 2GIG GC3/3e that are Alarm.com compatible.
Go!Control and GC2
There are a couple ways to find the cellular module number, through programming or by physically checking the module.
If you have the Installer Code (default 1561) you can click on the logo in the lower right hand corner of the screen to access the Installer Toolbox. From there click on Radio Status. The line Serial Number contains the 15-digit cellular module. If your module is unregistered you can put it into into this tool here to determine if the module is 3G or 4G LTE.
You can physically check the module by disarming the panel, powering it down completely, power supply first, then the internal battery and opening the panel. If you have active service, you will want to place your account on test mode before doing so, to avoid any false alarms.
The 4G LTE module installed inside will have 2 antennas attached as referenced in the following picture:
2GIG-LTEV-A-GC2-293x300
If the module only has one antenna, then it is 3G and should be replaced.
Additionally, the bare minimum firmware requirement for the 2GIG Go!Control or GC2 would be firmware 1.17 If your panel’s firmware is below 1.17, the module inside is 3G. You can check your panels firmware by navigating Security > Menu > Toolbox > Enter Master or Installer Code > Version.
The newest module’s require the panel to be on firmware 1.19.4.
GC3
With the GC3, you can find the 15-digit cellular module number by navigating to System Settings > Installer Toolbox > Enter Installer Code (default 1561) > Radio Status. The 15-digit cellular module number follows Serial Number:.
If you need to physically check, the module is installed in the side of the panel and can be revealed by lifting the module bay door off. The 3G and 4G LTE modules are identical physically so you will want to look at the part number listed on the module itself. You can also find the 15-digit cellular module number on the module sticker.
4G LTE Modules:
2GIG-LTEV1-A-GC3 is the Verizon module, requires FW 3.1.3+
2GIG-LTEA-A-GC3 is the AT&T module and requires FW 3.2.3+
3G Modules:
2GIG-3GA-GC3 , 2GIG-CDMAV-A-GC3
You can check firmware locally via System Info and Usage > System Info. Minimum firmware for 4G LTE modules is 3.1.3.
Qolsys
Qolsys panels are really easy to tell if you have 3G or 4G LTE.
IQ Panel 2/2+, the IQ Panel 4, and the IQ 4 Hub
All IQ Panel 2, IQ Panel 2+, and the IQ Panel 4 panels have an integrated 4G LTE module and can be used to sign up for new service.
You can find the 15-digit IMEI number printed on the back of the panel and on the box it comes in. You can also find it through programming. To do so:
  • Click Settings
  • Click Advanced Settings and enter the Installer (1111) or Master User (1234) code.
  • Click About, then Cellular.
IQ Panel Generation 1
If you have the first generation IQ Panel, it has a 3G radio installed. The modules are integrated and cannot be replaced on these panels. This panel cannot be used to sign up for service.
Interlogix Concord 4
Concord 4 modules are separate devices that are mounted outside of the alarm panel can, either nearby or run farther to an outer wall or attic, wherever the best signal is.
The 3G and 4G LTE modules will look similar on the outside, so you will need to open them to identify which version it is.
Opening the white plastic cover will reveal the module itself. You should find a 15-digit cellular module number printed on a sticker in the format SN:XXXXX-XXXXXXXXXX
4G LTE Module part numbers:
600-1053-4-ZX-AT AT&T 4G LTE Module w/ Z-Wave
600-1053-4-ZX-VZ Verizon 4G LTE Module w/ Z-wave
CD-411-US-AT AT&T 4G LTE w/ Z-Wave
CD-421-US-VZ Verizon 4G LTE w/ Z-Wave
Once you have identified the 15-digit module number, use this tool here to see if the module is unregistered and ready for use.
Interlogix NetworX (NX) Panel
Similar to the Concord, NX modules are separate devices that are mounted outside of the alarm panel can, either nearby or run farther to an outer wall or attic, wherever the best signal is.
NX-592E-LTE-ZX-VZ: 4G LTE Z-Wave Verizon
NX-411-US-AT 4G LTE AT&T
NX-410-US-VZ 4G LTE Verizon
Interlogix Simon XT, XTi, XTi-5
Simon XT
Simon XTi
Simon XTi-5
The Simon series of panels all use the same module, which is installed inside the panel. You will need to disarm the panel and open it up to find the module and identify the 15-digit cellular module number
The 4G LTE module will have 2 separate antenna and the 15-digit cellular module number can be found printed on a sticker attached to the module itself and will follow S/N IMEI:
  • 600-1048-XT-LTE-VZ Verizon 4G LTE w/ Z-Wave (Interlogix Part Number)
  • 600-1048-XT-ZX-AT AT&T 4G LTE w/Z-Wave (Interlogix Part Number)
  • XT-510-US-DP-VZ Verizon 4G LTE w/Z-Wave and Dual Path (Alarm.com part number)
  • XT-510-US-DP-AT AT&T 4G LTE w/Z-Wave and Dual Path (Alarm.com part number)
  • XT-511-US-VZ Verizon 4G LTE w/Z-Wave (Alarm.com part number)
  • XT-511-US-AT AT&T 4G LTE w/Z-Wave (Alarm.com part number)
If using the Simon XT panel, firmware 1.3+ is required for 4G LTE compatibility. The firmware version of an Interlogix Simon XT can be found in the panel.
To find the firmware version of an Interlogix Simon XT using the panel:
  1. Verify the system is disarmed.
  2. From the Disarmed home screen, press the up or down arrow until Revision appears. The number next to Revision is the firmware version of the panel.
DSC Impassa
Using the keypad:
  • Press and hold [1] for 10 seconds. The Serial Number used for Alarm.com displays on the screen.
On cellular modules:
The serial number is printed on the cellular module following IMEI: printed on the module board found inside the module case:
DSC Impassa Dual-Path LTE Module (TL8055LT)
