Thanks. Ive tried all three ways to connect the camera; bia Alarm.com app, AP mode and WPS. My internet router is starlink with no WPS button/mode. Any suggestions?
I had understood since starlink had no bandwidth restrictions it wiuld be ok. I was able to get my Qpanel to hook upbto internet and camera to use the Qpanel as a wifi access point. The camera has a solid green light….???
ADC states incompatibility with Satellite, as above. I can’t speak to the exact technical reasons, but in addition to bandwidth, latency is higher with satellite options, and connection reliability is lower.
Yeah I can see the reliability issue concern. Maybe this can help someone with SL internet. I got it to work finally after trying most of the day. I made sure my IQ panel was hooked to the SL wifi. Then set the camera so the white light was blinking and then set it into the IQ panels Access Point. Then went through the mobile app process. In that sequence it recognized the cameras firmware needed updating and after it updated it is now working as it should.
