jwcsurety
(Jason)
1
2GIG-DW10-345 Thin Door/Window Contact, Programmed for an Entry Door
- Sensor Type: 01 - Exit Entry 1
- Equipment Code: (0862) 2GIG Thin Door/Window Contact
- Serial Number: Learn - Trip Sensor
- Equipment Age: New
- Sensor Loop: 2
- Transmission Delay: Disabled
- Voice Descriptor: As Desired
- Sensor Reports: Enabled
- Sensor Supervised: Enabled
- Sensor Chime: As desired
The following video shows a walkthrough of adding this sensor to your alarm panel.
jwcsurety
(Jason)
2
2GIG-DW10-345 Thin Door/Window Contact, Programmed for a Window
- Sensor Type: 03 - Perimeter
- Sensor Loop: 2
jwcsurety
(Jason)
3
2GIG-DW10-345 Thin Door/Window Contact, Programmed for a Wired Input
- Sensor Type: Based on the wired sensor type used
- Sensor Loop: 1
The following video shows a walkthrough of adding an example usage of the wired input to your alarm panel.
jwcsurety
(Jason)
4
2GIG-DW20R-345 Recessed Door Contact
- Equipment Code: (0863) 2GIG Recessed Door Contact
- Sensor Loop: 1
jwcsurety
(Jason)
5
2GIG-PIR1-345 Motion Detector
- Sensor Type: 04 - Interior Follower
- Equipment Type: Motion
- Equipment Code: (0869) 2GIG PIR Motion Detector
- Sensor Loop: 1
- Sensor Chime: Disabled
jwcsurety
(Jason)
6
2GIG-GB1-345 Glass Break Detector
- Equipment Type: Contact
- Equipment Code: (0864) 2GIG Glass Break Detector
- Sensor Loop: 1
- Sensor Chime: As Desired
jwcsurety
(Jason)
7
2GIG-SMKT3-345 Smoke/Heat/Freeze Detector
- Sensor Type: 09 - 24 Hour Fire
- Equipment Code: (1058) 2GIG Smoke Detector
- Serial Number: Learn - Tamper Sensor
- Sensor Loop: 1
- Voice Descriptor: Smoke Detector
- Sensor Loop: 2
- Voice Descriptor: Heat Detector
- Sensor Type: 08 - 24 Hour Auxiliary Alarm
- Equipment Type: Freeze
- Sensor Loop: 3
- Voice Descriptor: Freeze Detector
jwcsurety
(Jason)
8
2GIG-CO3-345/CO8-345 Carbon Monoxide Detector
- Sensor Type: 14 - 24 Hour Carbon Monoxide
- Equipment Code: (1026) 2GIG CO Detector
- Sensor Loop: 1
- Voice Descriptor: Carbon Monoxide Detector
tyler
(Tyler)
10
How to Delete a Sensor from the 2GIG GC3
To delete a sensor, from the panel home screen navigate to:
- System Settings
- Enter Installer Code (default 1561)
- Scroll down to Installer Toolbox
- Select System Configuration
- Wireless Zones
- Select the zone (sensor) you wish to delete and click the Trashcan Icon.
- Select Reset
- Click the Return To System Configuration button to exit saving changes
