Garage
| Integration | IQ Panel 4/ IQ4 Hub Firmware | IQ Panel 2 Firmware |
| LiftMaster | 4.0.0+ | 2.4.0+ |
| Genie and Overhead Door | 4.0.0+ | 2.4.0+ |
LiftMaster:
- LiftMaster, Chamberlain, Craftsman, or Raynor Overhead Garage Door Opener
- LiftMaster MY Smart Garage Hub
- LiftMaster MuQ Retrofit with internet gateway (828LM) & Control Panel (888LM/889LM)
- GATES WILL NOT WORK
You can read more about the LiftMaster Integration process here
Genie and overhead door:
- Genie Aladdin Connect Retrofit Kit
- Gennie Aladdin or Overhead Anywhere Wi-Fi Garage Door Opener
You can read about the Genie and Overhead Door integrations process here
Lights
| Lutron | 4.3.0+ | Not Available |
| Deako | 4.3.0+ | Not Available |
| iDevices | 4.3.0+ | Not Available |
| Jasco Pro | 4.3.0+ | Not Available |
Lutron:
- Lutron Caseta, Ra2 Select, and RadioRa3
- RadioRa2 and Homeworks QS
You can read more about the Lutron Integration process here
Deako:
- Deako Smart Switch and Smart Dimmer
- Deako Wi-Fi Smart Plug
iDevices:
- iDevices Wi-Fi Lighting
- iDevices Z-Wave In-Wall Smart Dimmer (IDEVZ05DW/61303)
- iDevices Z-Wave In-Wall Smart Switch (IDEVZ01DW/61301)
- iDevices Z-Wave In-Wall Tamper Resistant Smart Outlet (IDEVZ08W/61304)
Jasco Pro:
- Jasco Pro Series Wi-Fi In-Wall Smart Switch
- Jasco Pro Series Wi-Fi In-Wall Toggle Smart Switch
Solar
| Solar Edge | 4.3.0+ | 2.8.1+ |
| Enphase | 4.3.0+ | 2.8.1+ |
You can read mor about Solar Integration process here
