IQ Panel 4 LED Status Lights after 4.3.0 update
I prefer the brightness of the IQ Panel 4 LED Status Lights to be at the minimum possible. However, after applying the 4.3.0 software update the LEDs are lit to their brightest whenever I arm or disarm the system.
The settings tray shows the LED slider positioned at the left side where I had configured it. In order to dim the LEDs I have to move the slider slightly and reposition it back where I want it. Each time I arm/disarm I have to go through this process again.
Thank you for reporting, I will forward to Qolsys, can you confirm whether the same issue occurs after a panel reboot?
Settings > Advanced Settings > Reboot Panel.
Could you clarify how I turn down the LED Status lights? Not clear on exactly where to go
I rebooted the panel a few minutes ago, and after arming or disarming the LEDs change to full brightness.
@ surety support
I do not have the slider bars for the LEDs per the picture yet I upgraded to the latest software. Can you help me?
  1. Swipe down ​to access settings tray ​and touch “Settings.”
  2. Touch “Display.”
  3. Scroll down to “Status Leds” row.
  4. Touch toggle to enable.
  5. ​The ​LED brightness slider is now visible on ​the ​​settings tray.
Did my instructions work for you?
Hi, can you tell me if the original issue has been resolved?
No, it is not resolved.
It will likely require a resolution in a future firmware release. Hopefully they can get it added to firmware they are currently working on.
