How To Factory reset an ADC-VDB750 to its default settings
Resetting a video device to its factory defaults removes all programming from the device. You will need to remove the VDB750 from the Alarm.com account, then re-add, after factory resetting the camera.
Important: Wait at least two minutes for the video device to power on fully before performing the following procedure. The factory reset might fail if the device is still powering on.
  1. Press and hold the doorbell button for at least 45-50 seconds until the LED starts blinking red and green.
  2. Wait for the device to reboot.
More information on installation and use of the VDB750 camera can be found here:
