This guide will show you how to create Widgets on your Android device to trigger Alarm.com Scenes at the touch of a button without having to open the Alarm.com app to do so.
This is a very handy feature, especially if you fire up a scene or two with regularity.
Android widget requirements
Usage of Android widgets require certain device and account requirements:
- Must have an Alarm.com connected system compatible with scenes.
- Android 4.0 or higher: The Android widgets feature requires a phone or tablet running
Android OS 4.0 or higher. - Alarm.com app version 3.7 or higher.
- Seamless login: must stay logged into the app (with the “keep me logged in” option checked on the app). If not, customers will be asked to log in when attempting to trigger a scene.
Let’s get Started
- Start off by navigating to your mobile device’s Widgets page.
Accessing the Widgets menu can be a different process for different Android devices. Sometimes it will be an option from the Apps menu.
Other times it will be accessed by pressing and holding (long press) the home screen to get the Home Screen menu to appear.
(Galaxy S8 example)
- Tap on the Alarm.com Widget to select it and open up the Alarm.com Scenes menu.
In some Android phone models and various operating systems, the Android widget is named Scenes rather than Alarm.com. When searching for available widgets, search for Alarm.com and/orScenes.
- Select the Scene you would like to be bound to the widget from your list of Scenes in Alarm.com
You will need to create the desired Scene ahead of time in order to select it. More on creating a scene can be found here.
- The Scene’s chosen icon will show up as a widget on your Android devices page.
You can drag and drop the widget to the location/page of your choice just like any other app icon.
Pressing on the bounding box (blue outline) will allow you to alter the size of the widget icon
- You can tap on the widget whenever you want to activate that Scene in alarm.com!
- You can long press the widget icon to delete should you need to.
