So I have an Enerwave ZWN-RSM2 Dual Switch Relay. When I join it to the 2Gig GoControl, it only shows up as a single switch that controls relay 1.
I was expecting for this to learn as two separate switches.
Only thing I see is that it uses the Multi Channel Command class for differentiating between the relays.
If this z-wave command class supported by the GoControl panel? If not, will there be an update to support these multi relay devices?
