Alarm.com Multi-Channel Z-Wave Switch Beta Testing
Surety customers are now able to beta test Alarm.com’s coming support for multi-channel Z-Wave switches. If you have a multi-channel Z-Wave switch, you should now be able to use all of the endpoints (plugs or lights) in Alarm.com.
Requires a control panel that supports multi-channel Z-Wave.
What are Multi-Channel Z-Wave Switches?
Multi-channel Z-Wave switches are those that have more than one independent controllable output on a single Z-Wave device. Often, these are Z-Wave switches with 2 or more plugs that you can power devices & appliances with and control them independently. Relay modules with multiple dry-contact outputs and in-wall switches that control both a light and a fan are also common multi-channel Z-Wave devices.
How Do I Add Multi-Channel Switches To My Alarm.com Account?
Add them to your control panel like any other Z-Wave device. During the discovery process, Alarm.com will notice that it’s multi-channel and will add a switch on Alarm.com for each endpoint.
If your multi-channel device is already on your Alarm.com account, you will need to remove it and then re-add it in order for it to be detected as a multi-channel device during the discovery process.
After you’ve added (or removed) a Z-wave device from your control panel, use System Manager to immediately send the new Z-Wave device list to Alarm.com. This isn’t required but if you don’t then it may take a while before Alarm.com sees the new device.
What Limitations Are There?
While most multi-channel switches should work fine, some older devices may have issues, for example with reporting status updates. We’re not sure which ones, that’s why we’re beta testing. We want you to try it and let us know!
If your multi-channel Z-wave switch has power-metering, that’s not yet supported for each endpoint. Controlling each endpoint should work but power-metering may show inaccurate usage date.
Endpoint names don’t yet automatically sync between the control panel and Alarm.com. If you change the name of the switch in Alarm.com the name of the endpoint on the control panel won’t change with it. This is expected to be fixed soon but for now the workaround is to change the name both on Alarm.com and in the control panel.
Which Multi-Channel Z-Wave Switches Work With Alarm.com?
That’s why we’re beta testing, to find out! If you have a multi-channel Z-Wave device, please try adding it to your Alarm.com account and reply below to let us know how it works for you. Thanks!
The Zooz ZEN16 Z-Wave Multi-Relay works well with my IQ Panel 4. All 3 relays show up in Alarm.com as light switches and work as expected.
Yes! I’m seeing the following on my IQ4:
My Zooz ZEN16 came over (seeing three relays), as did my ZEN14 Outdoor Plugs. (Showing both plugs as independently controllable.)
Note that I did not need to delete and re-add, they just showed up when I sent the Zwave device list, but the old object was in there as well creating duplicates. I am in the process of deleting and readding to clean up the duplicate devices.
I’m not sure if I should add this here or post it elsewhere, but just an FYI.
Not sure if related directly to this beta, but when I deleted and re-added all my devices with multiple channels/outlets, after that process everything z-wave going through the IQ4 panel got very slow. Commands to change a device status would happen about 5 minutes later, if at all.
After waiting about 20 minutes, I had the z-wave network re-discover itself, but the problem persisted. I then rebooted the panel, and with that the problem went away.
Just adding this for information’s sake in case it is related somehow.
Linking post from another topic about potential ZEN14 issues…
Good to know. Thanks! I’m curious, after you removed and re-added your multi-channel devices, did it fix the problem you described above where the ZEN14 plugs controlling your holiday lights were sometimes showing incorrect status in Alarm.com?
I’m wondering because Alarm.com said you have to remove them and re-add them but you said they showed up after just re-sending the z-wave device list to Alarm.com, which might not be a supported way of discovering additional endpoints.
P.S. yes, this topic is the appropriate place to report any issues you have with multi-channel z-wave devices during the beta test period.
Yes, the incorrect status issue was after I deleted and re-added the devices.
(Even though they just ‘showed up’ I deleted and re-added them all just for safe measure before I tried to really use them)
Will this also work if I have the zigbee daughter card for zigbee multi channel switches?
I don’t think so. AFAIK this is just for Z-Wave multi-channel switches. If multi-channel Zigbee works for you that would be a pleasant surprise but I doubt it.
The ZEN20 5-plug power strip works. All 5 plugs are controllable in Alarm.com. No issues with functionality.
Even the 2 USB charger ports show up in Alarm.com as switches. You can’t control them but you can see when a device is plugged in and charging. The status updates in Alarm.com were surprisingly quick, almost immediate.
Does the Qolsys IQ Panel 2+ support this capability?
Multi-channel Z-Wave was added to the IQ Panel 2 software in version 2.2.0 so I suspect yes. But I don’t have an IQ Panel 2+ here to test with, only an IQ Panel 4.
Does anyone have an IQ Panel 2+ and a multi-channel Z-Wave device to try it?
I’ll try to get a list of support control panels and software versions from Alarm.com.
I tested with a Zooz Zen20 and while the panel adds it properly and all plugs can be controlled by the panel individually, it only populates and works as a single all-on/all-off node through Alarm.com on my IQ Panel 2+ on 2.8.1.
@darren.stp, I saw this in another topic.
Just confirming here, the ZEN30 worked properly with Alarm.com multi-channel?
Thanks for asking !! I just re-tested this… Both of my ZEN30’s are using the relay button as a scene control so I had to re-test the scenario of having a real load on the relay.
Apparently it is not working properly with multi-channel, but is close:
Primary dimmer works fine.
The relay shows in ADC, but appears as a dimmer when it is really an on/off switch. Also ADC tries to control the relay, but the on/off actions do nothing. However if you manually actuate the relay button, its status in ADC is promptly updated and correct.
Both the dimmer and the relay work fine from the IQ 4 panel. So the issues appear to be limited to the ADC environment.
Just out of curiosity has there been any progress on this? I have a zen30 installed for control of lights (dimmer) and fan (relay). Would love to get the relay to work on ADC as well.
I haven’t heard anything regarding the zen30 relay. Does it still behave in the same way as the prior user described?
We can describe it to the ADC team working on this and see if they can prioritize support.
Hi Jason,
Just to add to this a bit - since you may be reaching out to ADC about the ZEN30…
There is also a second issue with the ZEN30 concerning building zwave direct associations. I meant to send this over to you but forgot!
If I build a direct association from the Zen30’s second button (the relay button) to another switch - say a ZEN76 such that I want to turn the 76 off and on by pressing the relay button on the ZEN30, it does not work. I actually opened a ticket with Zooz on this and also posted on their forum. We believe this is an issue with the IQ 4 itself. If I set up the same scenario in Home Assistant, or on the Zooz Z-box, the associations work perfectly. They just don’t work on the IQ 4. (The association builds, but it actually does not do any control.)
Zooz confirmed this in their lab, as per the Zooz community discussion.
Here’s a link to the discussion on the Zooz forum about this problem:
(Post #6 in this thread has the best summary of behavior)
Deleted and readded the Intermatic CA3750, still only showing up as a single switch, no control over the twin relays that I’m seeing. Not sure if perhaps there is a different procedure I needed to follow.
Here is a link to devices that can work with the IQ Panel.
I do see you are currently running an older software on your panel. Can you update to the latest firmware version 4.6.1 and test again.
To update, you need to do it in increments. The first update should be to 4.4.2 and then followed by 4.6.1. Instructions for the updates can be found in the Firmware release information as and I will also include a video with step by step on updating. Just be sure you use the correct patch tag.
