WA3000 9.12 Install
New setup with a repurposed WA-3000 9.12 and a Alarm.com Honeywell Vista System Enhancement Module. Followed this guide although not all commands work on my system. I do get 1 way communication and alerts when i manually arm and disarm but I can’t arm or disarm via the alarm.com app.
No red lights on the SEM; just flashing path and signal LEDs along with power
When *29 is set to 1 I get a Check 103 long range 0000
*196 is set; dip switches 2 and 3 ON
Envisalink 4 on Address 18 - works fine and can arm and disarm remotely
I have a different installer code than default - Master code set correctly in the app under user name
Any other ideas?
If there are no troubles on your panel and LED1 is not lighting up, the master code may need to be synced with alarm.com. To do this, the master code on both alarm.com and the panel to 1234. Then change it through alarm.com. Instructions in the link below
no change - I changed both the user code in the app and the master code on the vista 20p back to 1234; reset power; armed and disarmed - no flashing red light, the 2nd green light does one long flash, the 3rd does 3 short flashes. Still get a check 103 long range 0000 error and the keypad beeps after a few minutes.
i get notifications when i arm and disarm from the keypad in the alarm.com app but i can’t arm and disarm from the app. I also can’t change the user code from the app it just hangs
Can you send a picture of the wiring at the panel?
Also, it looks like it is having trouble syncing the sensors. Can you enter programming and try changing the installer code and then rebooting the panel. Once it reboots and performs a system scan, you can change the installer code back
