Users can configure the ADC-VDB750’s motion detection settings to only capture what is important. Follow these guidelines to optimize motion detection.
To adjust the sensitivity using the Alarm.com Website:
- Log into the Customer Website.
- Tap Video.
- Tap Settings Gear.
- Tap Recording Rules.
- Tap Edit Pencilon the desired rule.
- Using the Sensitivity slider, adjust the sensitivity up to increase the sensitivity or down to decrease the sensitivity.
- Tap Save.
To adjust the sensitivity using the Customer app:
- Log into the Customer app.
- Click Video.
- Click Recording Rules.
- Click Edit Pencil on the desired rule.
- Click Save.
Verify the Ground Zone is configured correctly
- Avoid overlapping ground zones with objects that are prone to movement (e.g., such as trees, bushes, or other objects that move in the wind).
- Only draw the rule where the feet of the person should enter.
- Do not increase the size of the Ground Zone to cover the whole of the person.
- Do not include walls, trees, or other structures in the rule/selection.
- After observing what the rule detects over a few days, consider adjusting the Detection Sensitivity slider higher for more triggers or lower for fewer.
For more information about Video Analytics best practices in general, see below:
For more information on Installation and use of the VDB750 see the following:
