Qolsys IQ Pro Smart Rules
I want to activate a partition, once two motion sensors have not been activated in 3 hours.
I see pictures of Smart Rules in Alarm.com, but can’t find that in my (master) login.
Any advise?
Smart Arming is not available for systems using partitions.
You can use the Auto-Rearming feature with the Arming Schedules add-on to arm a partition based on inactivity for a certain amount of time, but this takes all sensor activity in all partitions into consideration before arming a partition.
Thanks for the reply. I am in shock. Such advanced systems and I can not do such a simple job.
Qolsys and Alarm.com limit automations to what’s commonly used and keeps them pretty simple. That’s why we’re building this.
We just recently posted an example of setting up an automation that’s based on multiple sensors. In your case you would program it to arm a partition instead of tripping a sensor.
We can try to put together the automation you’re looking for if you want to try it. Let me know.
Wow! What a project!
Let me try to get approval for that.
Be aware it’s a brand new project that’s being developed. It comes with a warning that says, “IQ Mate is an open source project and a work in progress. It has not been thoroughly tested and is more a proof-of-concept right now. Use it at your own risk.”
That being said, it mostly just packages together things that are well-tested in a Docker container. It uses Node-RED (very well tested) and Qolsys Gateway (not as heavily used but it’s been around for a while).
