Firmware upgrade (Panel)
- All panels must be updated to 4.3.0n
- During the firmware upgrade IQ Installer will disconnect, this is expected behavior.
- Always wait for the panel LED to turn green after an update, trying to connect with IQ Installer, rebooting or powering down the system during the update may result in instability.
V1.39 keypad update
- Enroll on a 4.3.0n panel.
- Connect keypads on a short wire run.
- Keypads will update to v1.50
- Each unique firmware version on the keypad will take 10-15 minutes to update.
- Updates are concurrent – as an example, 2 different firmware versions on keypads
will take approximately 30 minutes to update. - DO NOT touch the keypad(s) until you see firmware upgrade in progress and the keypad(s)reboot
IQR-PG
- Pairing
- Pairing an IQR-PG is a process, it needs to download any updates available
and will reboot up to 3 times – be patient.
- Firmware upgrade
- To avoid confusion- below is the terminology used.
- PowerG Paired = the remote is paired via PowerG - You can still
connect to a WiFi network when utilizing PowerG pairing. - WiFi Paired = the remote is paired via WiFi
- Always ensure that the IQR-PG is updated prior to utilizing the IQR-PG
- If firmware is not updating automatically on PowerG paired IQR-PG, drag down the settings tray and click IQ Remote PG Upgrade – the remote will
check in and download updates - please note the remote must either be connected (not paired) to the same WiFi network as the panel or within range of the Panel AP (~30 feet)
- Camera streaming
- Currently on 4.3.0n video streaming to IQR-PG is not officially supported.
PowerG Host / RF Keypad Limitations
- Limitations when utilizing the HS2LCDRF or the HSM2HOST9 the following are not
supported.- IQR-PG
- PG9WLSHW8 / PG9HRDW8
- PowerG Photo Beams (PG9200AX/PG9350SL)
- PowerG Automation devices
- PowerG+ sensors
- IMPORTANT NOTE: Qolsys should be releasing a PGPHost9 module summer 2024 that will support these devices
IQ Installer (best practices)
- If you can’t arm the system, make sure IQ Installer is not connected.
- Whenever possible, use IQ Installer for local firmware updates, you are not reliant
on the customers network and the upgrade process is quicker. - Always ensure that the IQ Pro Blue LED is flashing before attempting to start an IQ
Installer pairing session.
Hardwired Keypad best practices
- Disable auto bypass (in IQ Installer) so the green ready check mark turns off when a zone is open.
- HS2LCD(RF)(P)- Firmware version 1.4(x) not supported. 1.4(x) keypads will need to
either be updated with DLS5 or swapped for compatible versions
MX Diagnostics
- Within the IQ Installer HSM3105 menu you will see a button for a MX Diagnostics
tool, that will help you with installation and troubleshooting of MX Devices.
MX Enrollment
- Ensure in HSM3105 programming that the loop configuration (2 Wire Spur or
4-wire loop) and the Power mode (High or Low Power mode) is correctly set. - MX Enrollment will take 5 minutes (keep IQ Installer in the foreground during this
time) BE PATIENT
HS2TCH(P) firmware update
- Always ensure you download and install the SD Card firmware that is posted in the
TSB. - Most IQ Pro updates will include a SD Card update the HS2TCH(P)
Port requirements
- Panel
- 7443(TCP), 8443(TCP), 9443(UDP), 5959(UDP), 1121(UDP)
- IQ Installer / IQ Remote
- 8883(TCP) for local communication
Corbus Module Auto Firmware Update Information
This document provides details regarding the process of updating Corbus module firmware automatically and outlines the restrictions associated with auto updates. Additionally, it includes a table specifying the minimum acceptable version for auto updates, considering certain Neo modules requiring a bridge file, which IQPRO does not support.
Update Process Overview:
- Preconditions: File transfer will not initiate if the panel’s AC or battery is
unplugged or if the battery level is low. - Duration: The file transfer process typically takes between 10 to 20 minutes
per module type. - Sequence: File transfer occurs sequentially for each module type, following
a first-come-first-serve order. For example, module types such as HS2LCDN,
HS2LCD non-N, HS2LCDRF, HSM3105, etc. - Background Transfer: File transfer occurs in the background without user
notification. Upon completion, the keypad displays “Firmware update in
Progress” while applying the update, a process lasting approximately 30-60
seconds. - Trigger: Firmware update checks are performed either upon module
enrollment or every time the panel is rebooted.
Auto Update Min Version Table for IQPRO V4.3
| Module | Min Supported | Supported Upd. Ver. IQPRO V4.3 |
| HS2LCD N | 1.32 | 1.35 |
| HS2LCD | 1.11 | 1.35 |
| HS2LCDRFN | 1.34 | 1.38 |
| HS2LCDRF | 1.11 | 1.38 |
| HSM2HOST | 1.1 | 1.33 |
| HS2TCH N | 1.3 | 1.35 (SD Card update required - UI) |
| HS2TCH | 1.03 | 1.35 (SD Card updated require - UI) |
| HS2LCDRF/HS2LCD (AKA G keypad) | 1.39 | 1.50 |
| HSM3105 | 1.31.00.31 | 1.31.00.32 |
Note: It is strongly advised to perform a complete system reboot by removing the power source after an automatic firmware update for PGH, PGHP, and LCDRF keypads. This step should be taken before enrolling any PG devices to ensure seamless functionality and optimal performance
