Panel Boot Failure
Having “Initial Boot Failure” (IBF) issue with IQ-4 panel now.
Panel is brand new, unused.
Panel will not boot on 3s power button use.
Using unmodified, factory power supply “Barrel Jack” and Power is present at panel.
Panel would not boot on wall.
Assumed BUB (backup battery) issue…
Panel is face down on desk during this process, back mtng plate removed…
  1. Power disconnected via barrel jack,
  2. BUB unplugged from sys brd, 5 sec,
  3. BUB plugged back in,
    (No status change)
  4. BJ (Barrel Jack) re-connected.
    (Panel flashes re 1 time then continuous red LED 10 sec then flashes blu LED 3 times and goes black.)
Process has been repeated 5 times thus far.
NEW DEVELOPEMENT:
After 8 repeats, panel has started a continuous series of Blu flashing LED.
CONTINUEING DEVELOPEMENT:
After aprx 3 min flashing Blu LED, Blu LED went continuous for aprx 3 sec then changed to continuous Grn LED.
After replacing rear mtng plate, Panel (still on desktop) is in Grn LED continuous condition and initial boot sequence has automatically started.
Assumed BUB has been successfully, sufficiently charged for proper boot.
Thank you for letting us know.
Has the panel fully booted up? I show that your account still has the IQ Panel 2+ associated with it, and the system is not communicating with Alarm.com at this time.
If you need us to switch the IMEI number on the account, please send us a private message with the IMEI number for the new system.
“Has the panel fully booted up?”
Yes. Waiting for Surity connection.
“I show that your account still has the IQ Panel 2+”
That was the old system I entered the IMEI incorrectly
“If you need us to switch the IMEI number on the account”
Already sent the new IMEI via this system. Awaiting your action.
Ran setup
Received backend connection error.
“Didn’t get receipt from back end”
Skipped and continued setup with no issues except “Backend Receipt Failure”.
Panel then updated software.
Panel rebooted and started the setup process all over again but retained all previous info.
Skipped all screens.
Panel then settled into normal operations mode.
Accessed “Advanced Settings” and ran cellular test.
Cellular test passed.
All currently appears nominal.
(occasionally I miss this work)
QUESTION:
I have the new QualSys IQ4 panel hooked up, my sensors and z-Waze linked and I tried to set up the app and it only links to my old ADT service.
How do I disassociate ADT from my app and connect you guys?
I can see that your panel is connected to and working with your Alarm.com account with us. But it says you haven’t yet logged into your Alarm.com account. Can you go to System Manager, wait for the Log into Alarm.com button to appear, and click that to log in for the first time and set your password?
What makes you say that you’re still associated with your ADT account?
If you are logging in to Alarm.com and it is going to a different provider account, that would suggest you are using an old username. Make sure you are using the desired Alarm.com username you entered in your activation form on our website.
I’ll work on that…
Short of setting off the alarm, How do I check for connection to monitoring service??
I am at this point, thoroughly confused.
Who the f*** is monitoring my security?
ADT or Surity?
I’ll work on that…
You will want to finish the initial set up process through the System Manager section of your Surety login first to get connected to your new Alarm.com account for the first time before proceeding with testing.
You can find a link to account login here:
Steps on how to test your system can be found here:
ADT or Surity?
ADT is not a part of this, they are a separate Alarm.com dealer.
Surety is the Alarm.com service provider. We are partnered with Becklar Monitoring for 24/7 professional monitoring.
More information on how professional monitoring works can be found here:
By default your 24/7 Professional Monitoring account is on Test Mode for 7 days following account creation. Test Mode is active until 7/9/2025.
Then why am I using an Alarm.com app that doesn’t recognize the Username and password I set up with you guys?
I am showing that you have not logged into your new Alarm.com account through Surety for the first time yet.
To proceed and finalize the connection process, do the following:
  1. Login to your Surety account: My Account - Surety
  2. Click on System Manager
  3. Click the blue Login to Alarm.com button in Step 3.
    • The Step 2 page may show for a bit when you first access System Manager. This is normal. The page will update to Step 3 after a time.
  4. Follow the instructions through Alarm.com and get connected.
