IQ Remote PowerG: Status LED goes off with screen since OTA update
My relatively new IQ Remote PowerG remote just today had an OTA update. I happened to see it updating. Since that finished, the LED status light goes dark when the screen timer goes dark (currently set to 1 minute). If I touch the screen or arm or disarm the system, it comes back on with the screen but then goes back off when the screen does.
Obviously this is new (and unwanted) behavior since today’s OTA update.
I have rebooted the unit but the problem persists.
It makes the LED pointless.
How can I get it to work like it did before this update?
Here’s the current version:
Software: 4.4.1
Build Number: rc0006_20230926
Linux Version: 4.4.71
Android OS Version: 7.1.2
Thanks,
Mark
To confirm, under Photo Frame settings on the IQR-PG, when Display Type set to Off, and the panel enters the Photo Frame Start Time, the arming status LED turns off along with the screen, correct?
Yep, exactly.
So, as a temporary solution I’ve changed the photo frame setting to display the clock instead of go off and now the LED stays on. It’s so weird. I’ve switched it back and and forth. The behavior remains consistent.
I’m 100% sure it was today’s update that did this. Hopefully a patch can fix it soon.
I can replicate with the Display Type set to Off. LED stays on when Display Type is set to the other variables.
This may be a bug or by design, I do not see documentation specifying this change however. I have reached out to Qolsys to confirm and will follow up here once I have more information.
Excellent. I appreciate it.
Mark
It appears that this is a bug and should be resolved in a future firmware update. I cannot say for certain when that would occur but you can stay up to date with FW releases and patch notes by following the below thread:
Very good. Thanks for the info.
Just noting the more recent thread here in case someone else runs into this issue (I imagine everyone who has this remote has this issue when the screen goes off):
Shame this issue has been in place for five months with no resolution.
Likely to be addressed in the next firmware update, 4.5.0, but wont know until the patch notes hit.
Any new information as to when this update might see the light of day?
Nothing specific but 4.5.0 should be dropping shortly which may resolve the issue.
I can confirm 4.5.0 resolves this issue. Yay!
I was just about to come here and say this, beat me to it!
How do you update the firmware to get the LED Light to stay on when the screen goes dim?
Depends on how the IQ Remote PG is connected to the IQ Panel 4.
First you would upgrade the IQ Panel 4 to 4.5.0+.
If the IQ Remote PG is connected via Wi-Fi, the IQ Remote should update and reboot automatically.
If the IQ Remote PG is connected via PowerG, it will not update automatically. You need to navigate to Settings > IQREMOTE PG UPGRADE at the IQ Remote.
