IQ Remote Low Pitch Hum
Every once in a while if the alarm has gone off, our IQ Remote has a low pitch squeal / hum that is constant. In the past, I’ve tripped another alarm and it resets itself. This time I can’t get the noise to go away - the panel is in our bedroom so this is not sustainable. Any thoughts or is it time to just get a new remote?
Sorry about the noise. A constant hum from the IQ Remote after an alarm usually means its speaker didn’t fully reset when the alarm ended. Here are a couple of things to try:
1. Restart the IQ Remote
  1. Unplug the IQ Remote’s power adapter.
  2. Press and hold the power button on the side of the IQ Remote until the power-off option appears, then turn it off.
  3. Leave it off for about 1 minute.
  4. Plug the power adapter back in and turn the IQ Remote back on.
2. Restart the main panel
If the hum comes back, restart your IQ Panel 2 as well, since the IQ Remote takes its sound cues from the panel:
  1. Swipe down from the top of the panel screen and touch Settings.
  2. Touch Advanced Settings and enter your installer code (default 1111).
  3. Touch System, then Power Down.
  4. Once it’s off, press the power button to turn it back on.
We’ve confirmed your system is already on the latest software, so an update won’t fix this.
If the hum keeps coming back
The IQ Remote’s speaker may be failing. Unfortunately, the IQ Panel 2 and its IQ Remote keypads have been discontinued, so a matching replacement is hard to find. Here are your options:
  • Replace the IQ Remote with a DSC WS9LCDWF9 wireless keypad. This PowerG keypad works with your IQ Panel 2 and may be easier to find from other distributors.
    • It lets you arm, disarm and send a panic alarm, and it shows the system’s status.
    • It’s a button keypad with an LCD screen, not a touchscreen.
    • It runs on 4 AA batteries, with an optional plug-in power adapter.
    • You can’t bypass sensors from it.
  • Upgrade to the IQ Panel 5 and the IQ Remote PowerG. You’d replace your IQ Panel 2 with the IQ Panel 5, and your current IQ Remote with the IQ Remote PowerG secondary touchscreen:
Let us know how the restart goes, or if you’d like help with either option.
Thanks for the reply. I did some further troubleshooting and wanted to share what I’ve observed.
I restarted both the main panel and the IQ remote, unfortunately the hum came back both times.
When I disconnected the power supply from the remote, the hum disappeared. Plugging it back in, the hum started again. I thought this is odd, if the panel is running on battery power it’s totally fine. Which led me down a google rabbit hole which suggested it may be the power supply that’s gone bad due to the sudden spike when the siren goes off. So… the question then is should I just replace the power supply to test that out before replacing both panels with the new versions? And, if so, does Surety sell the power supply alone?
Could you check the label on your IQ Remote’s current power supply and let us know the output voltage it lists? A photo of the label works too.
If it shows 7V, our 7VDC Transformer for Qolsys Panels ($21) should be a match: Replacement 7VDC Transformer for Qolsys Panels - QR0051-840 - Surety
If it shows a different voltage, let us know and we’ll help you find the right one.
If the hum continues with a new power supply, then the IQ Remote itself is likely the issue.
Please let us know if there is anything else we can do to help.
