I created a support request ticket asking for a “work around” to the 40 digit PIN code Qolsys wants. If it wasn’t for that perhaps my attempt could have been successful!! (BTW, I used a 50 foot Ethernet patch cable to get my ZNet next to my alarm panel! )
We received your ticket in Alarm.com and forwarded the details to Qolsys for review. They should be able to help describe what is possible.
The “40 Digit Code” is the S2 DSK (device specific key). This is needed for S2 inclusion, which may or may not be supported on your current controller.
In general it isn’t an officially supported process on any specific controller.
My ZNet does support S2 Security. The last three or four switches I’ve added did also so when I included them in my network I input their DSK’s so the controller can use S2 for communication. From what I read there’s little to no reason to use S2, S0 security is more than secure enough unless you’re defending against the FSB or Chinese equivalent. In any case, I would be happy to forgo S2 if that would allow me to add my existing network to IQ4 Panel! Thanks for checking into this!
Sorry this comment turned a little longer than I intended… I spent the better part of the weekend finally getting the IQ Panel 4 setup as a secondary controller in HA. It was not an easy process, and I wouldn’t recommend it unless you know what you are doing. But thought I’d share a few of my findings:
The current size/state of the network may impact if and how the IQ Panel will pair as a secondary. I tested successfully pairing on a clean/reset controller, reset again before rebuilding network and added ~50 devices, and then no matter what I did, the IQ Panel refused to join. The primary is never prompted for the DSK, only a few initial messages are exchanged according to the logs, and the IQ Panel Z-Wave radio seems to freeze up. It took rebooting or turning off/on the radio to do anything else (usually would get a “busy” error message until then). Nothing I did would allow it to pair, either using Z-Wave PC Controller or zwavejs in HA. Not sure if it just didn’t like the size of the network, the node IDs it was provisioned, or something else. When I then reset the primary controller, the IQ panel had zero problems joining.
Next I tried pairing it to the controller when there were ~20 devices on the network… this time it joined, but did not join as an inclusion controller. The include/clear buttons were locked out (stating that this must be done from the primary). Problem here is there is not a reliable way to update the IQ Panel as additional devices are added to the network, or if it didn’t learn everything initially. Some controllers will periodically query for new nodes if they are configured as a secondary, but it is not apparent that the IQ Panel implements this. You could clear and re-include the IQ Panel to the primary, but then you have to beware of encountering the first scenario above, as well as the fact that successfully learning ALL devices during that pair is unlikely.
When joining to a fresh network, or one with just a few devices, I never had any problem joining as a secondary inclusion controller.
When joined as an inclusion controller, beware of S2 issues with the primary controller. S2 makes using secondary controllers a bit more complex. You should check if your primary controller is compliant with the spec on implementing the SIS side of the Inclusion Controller Command Class and S2 bootstrapping. Zwavejs in HA is not compliant (well, yet… they are waiting on some hardware testing according to a PR on their git).
When pairing with S2, the SIS (ideally your primary controller) is responsible for S2 bootstrapping. So if you want the device to show on both the primary controller and the IQ Panel, you would include it to the IQ Panel, and then you should be prompted for the DSK on the primary. Or you could pair directly to the primary first, and then you could later include on the IQ Panel.
This was my ultimate process to getting things working… I used a Zooz 700 USB stick with the Z-Wave PC Controller tool, and have an IQ Panel 4 running the latest firmware.
Reset the stick in PC controller. And reset (Remove all Devices option) on the IQ Panel. You should see the “Add/Remove Controller” option appear. Start a remove in PC Controller, and a learn (Add/Remove Controller) on the IQ Panel to clear it. It should only take a few seconds and report successful on both. And then reset them both again for good measure.
At the top right in PC controller where the “shield” icon is, copy all the security keys. To ultimately use in HA for example, you need to statically set the keys in the add-on.
In PC Controller, set the primary device to be the SIS. If you join the IQ Panel without doing this, it will assume the SIS role, which we don’t want. In the controller info, you should see the role change to “SUC, RealPrimary, SIS, NodeIdServerPresent”.
Start an add in PC controller, and a learn on the IQ Panel. PC Controller should learn the IQ panel, and ask for the first 5 keys of the DSK shown on the IQ Panel for inclusion. You should end up learning 5 additional virtual devices as well and it should report successful on both devices. To be sure that bootstrapping all the way to S2 Access was a success, make sure the “Security Scheme” for the IQ Panel node in PC controller is set to Access, and that you can run a Get Node Info without issue. Also on the IQ Panel, the buttons for smart start and provisioning list should have disappeared.
To include a device that you want on both the IQ Panel and Primary, start inclusion on the IQ Panel like normal, and then after a few seconds PC controller will pop up asking for the DSK. If all goes according to plan, you should see the new node (with security) in both controllers.
Even though it’s discouraged from including devices with a “mobile” controller, I found this was often the most reliable way of ensuring successful S2 bootstrapping. Including devices was definitely more sensitive than normal, perhaps because there is another controller in the mix. So often I had to move the device, or the controllers to get a reliable pair, and deal with healing the routes later.
Don’t be afraid to reload PC Controller, disable/enable the radio in the IQ panel, or reboot… and often. Both PC Controller and the IQ Panel can be buggy and definitely had moments where they were not behaving as expected, and usually that was a sign to just give it the on/off.
Looks like you have found a path forward. I might try and replicate your method this weekend. I have a several smart switches and door locks so it could be an all weekend trial. Maybe Qolsys can move forward with addressing the issues you have identified if your work gets passed up to them.
Good luck! So far things are working fine, with a few caveats:
- Once finished including devices with PC Controller, it’s imperative that you make NVM backups. During testing, I was able to switch back and forth between PC controller and HA without issue. But about a week later I went to go add a few more devices and it seemed that the IQ Panel could no longer properly talk to the primary controller. I eventually restored the latest backup and things were back to normal… which tells me that ZWaveJS must have changed/broke something somehow on the USB stick. Also don’t be tempted to try re-including the IQ Panel to the primary thinking it could fix things (like a normal end-point may)… from my initial testing it seems the IQ Panel internally clears itself first, and ends up pairing again as a new device.
- How well you can keep device states in sync is going to be questionable. This isn’t an issue with either the IQ Panel or HA or any other controller… just a reality of the Z-Wave protocol. If your end-points support multiple lifeline group associations, that’ll usually keep both controllers in sync for events originated at the end-point (e.g manually triggering a switch). But most devices don’t “echo” their state. So for example if you trigger a switch from HA, the IQ panel may never know about it and assume it’s still on. Some surprising exceptions include the Alarm.com thermostats (requires changing a Z-Wave configuration setting), and my kwikset door lock. At least in HA, you can setup some periodic polling of devices to help with this.
I have gotten by with alarm.com integrations to get data for non-critical lights and even somewhat reliable door open/closure status.
The biggest need I have currently is syncing the door codes from alarm.com to my locks. I have not found any workarounds for that yet.
Home assistant automations are far superior to the ones on alarm.com so I can’t see switching back to a qolsys / alarm.com only setup ever again.
I would very much like to replicate your method on my IQ Panel 4 with a 700 Series USB Stick but have a couple of questions. In the lead up to step 1 you say you’re using the Zooz 700 stick and the “Z-Wave PC Controller Tool”. Are you talking about the Silicon Labs tool that comes packaged in their “Simplicity Studio Software Tool”? Or some other software? Also, any special steps taken when you switched from using the “Z-Wave PC Controller Tool” to using HA? How did HA learn all your Z-Wave Nodes? In may case I’ll be switching to Homeseer instead of HA but I’m hoping it will work also.
Thank you so much for the very detailed post on your approach!
Yup I was referring to the Silicon Labs tool. I can’t speak to whether any other controller software would work too (except for zwavejs presently), but that’s what I used.
Other than copying the keys over, no additional pairing steps were needing to populate the devices in HA. Much of the low level state of the network is stored in the controller chipset (such as paired slave devices). Any controller software should automatically pull all the devices during initialization, and only need to interview them to learn all the other attributes.
That sounds great! I’m waiting on delivery of a 700 Series USB Stick and hopefully I’ll be able to give it a try in the next couple of weeks. Will report back with results. Thanks for your help!
I finally got a hold of Z-Wave PC Controller and have been following your steps successfully so far.
Thank you for the very well written instructions and learning points!!
So far so good.
No problem! Glad to hear it’s working for you as well!
I spent most of Sunday getting 16 switches and door locks learned into both controllers. HA is primary and IQ Panel as secondary and I agree, this process is not for the faint of heart.
I was constantly resetting the IQ Panel and the Zooz stick / laptop over and over. Sometimes the process was smooth and worked flawlessly and then my luck would run out and it was back to resetting the stick, restoring the NVM backup and moving forward again.
Some things that made the process smoother for me was:
Remove - disassociate switches , door locks from both the Zooz stick and the IQ panel regardless of whether it was associated in the past or not.
Every time I associated a new device I backed up the NVM and that allowed me to continue to make progress even if the radios got hung up
I did not always need to reboot the IQ panel which takes a long time, most of the time I could just disable the Z-wave radio and then re-enable it and continue on
Take pictures of the QR code and the pin for every device that has one to keep from having to constantly take off and put back on the wall plates when things don’t go right the first, second, third time.
I can now sync my door locks with Alarm.com again thanks to you. My automations are much more responsive now that I do not have to pull information from alarm.com on alarm sensor data.
I will be upgrading and adding some switches with the zooz 700 series switches since I have some old z-wave devices that were the most stubborn and least reliable.
Great news!
Hey, Did you ever end up getting it working with Homeseer?
Sorry for the long delay, was in South Korea for several weeks. I kept putting off the experiment to completely rebuild my Z-Wave network with the paired Primary/Secondary HomeSeer/IQ4 Panel because several of my Z-Wave devices are old GE and Intermetec devices where the device and the controller have to be within inches of each other to join. Rather than go through all that pain I re-examined what it was that I wanted to achieve by having dual Z-Wave Controllers and realized that I like using Homeseer for automation and don’t really want to rely on Alarm.com for that. What I really want is to have status info of my Qolsys System provided to my Homeseer System so I dug and researched ways to do that. I now have Homeseer looking for and reacting to Arm/Disarm emails from Alarm.com so that it is aware of the Alarm System being set or not. Homeseer in turn can communicate that information to Blue Iris so everyone is relatively synchronized! This sync is not instantaneous of course but Alarm.com emails are fairly promt (no more than a minute in my experience) so for my purposes this is all I really need. And best of all I don’t need to rebuild and optimize my Z-Wave network all over again with dual controllers!
Glad I happened across this thread. For years now, I’ve been running an IQ Panel 2 as z-wave controller for most of my home automation stuff (lights, locks, ADC thermostat), then I have a SmartThings hub which primarily controls my home theater automation. Qolsys came first, and when I built my theater, I initially wanted to keep everything separate. Kept thinking about moving to ST as primary controller to use some of the extra power, but just never got around to it.
Fast forward to yesterday when my IQ panel had a total hardware failure, so I just ordered a Panel 4, and figured since I’m about to have to go through the fun of rebuilding most of the z-wave network, I’d use this is an opportunity to switch everything to ST and set the panel as a secondary so I could use some of the ST capabilities for more advanced automation. I was quite literally getting up this morning to start resetting all my devices so I could add them to the ST hub now and just need to add the panel as a secondary when it comes. Luckily I just happened to do a quick search on adding IQ 4 as a secondary before getting started only to find this thread. Figured I’d bump it to see if anything changed on the Qolsys side of things.
I assume based on what I see in here, there’s still no hope of adding IQ Panel to ST as a secondary controller, and no update from Qolsys?
It is not an officially supported process in the panel, per manufacturer. I cannot speak regarding ST specifically but this user post above in this thread describes what they did for another controller.
It is unfortunate that Qolsys has not addressed this in over 2 years. I am moving to an 800 series stick and adding some new 800 series sensors.
I guess I will be resetting and redoing the entire network again from scratch.
Home automation is a very real thing for most homeowners now. If Qolsys does not feel the need to support the customers wanting a more robust home automation system outside of the limited, internet based alarm.com . I might need to change alarm panels to a manufacturer who does, or just drop the dedicated panels all together…
I understand the frustration when that is the one feature you really want. I can’t speak for Qolsys regarding their development/support plans, but I can try to give my thoughts.
The Qolsys panel is designed specifically for use with Alarm.com, so I expect the primary focus to always be on ADC.
That said, a Control4 integration option was developed for the Qolsys panel, and I think the importance of home automation is recognized, with Qolsys maintaining far better internal testing/compatibility documents than other manufacturers I have experienced.
If I remember correctly, official support was dropped for secondary Z-wave controllers during the IQ Panel 2+ years after Z-wave product certification dropped that as a requirement for controllers. I assume the decision was at least partially due to the inability to guarantee results. When it was available there were still compatibility concerns and limitations on all panels that supported it, not just on Qolsys.
I didn’t agree with the decision at the time, both the removal of it as a certification requirement and Qolsys dropping it. We made a case for Qolsys to include it again. I’ve come to terms with the decision more, though I would still want it available with the caveat that problems may occur.
I don’t want to say this is an indication of a significant direction shift because I do not know how it will play out, however an addition to automation options has been announced in the form of PowerG automation devices. There is a lock, switch, dimmer, and plug-ins which are now supported on 4.4.0 firmware.
Overall performance will be known over time, but there is a significant functional benefit to the PowerG RF version, as they are two way communication, but direct from point to panel with ranges in the thousands of feet, rather than the dozens of some Z-wave devices.
