GfoGass94
(GfoGass94)
November 27, 2022, 5:22pm
1
how can I can add camera to panel?
jwcsurety
(Jason)
November 28, 2022, 3:57pm
2
You would need video support on your plan if you do not have it, which can be added to your subscription by visiting the system manager here .
You can then find a guide with links to specific device model steps below:
To enroll a camera, connect the camera to the local network, then associate the camera with the Alarm.com account.
There are three local options for connecting video devices to the network:
Ethernet,
Wi-Fi Protected Setup (WPS) Mode, and
Access Point (AP) Mode.
Some video devices can only be connected using some of those options, so verify which methods are supported before beginning the enrollment process.
Pre-enrollment checklist:
AC power adapter (required for non-PoE connections)
Broa…
Cameras are linked to your Alarm.com account, then you can select cameras within Alarm.com to stream to your panel if you have a model that is compatible.
Want to stream live video to your Qolsys IQ Panel 2/4 or IQ Remote but don’t know how? This guide is for you!
What do I need?
It’s pretty simple. You need the following:
Qolsys IQ Panel 2/2+ or IQ Panel 4
the IQ Remote can also stream video.
If using the IQR-PG IQ Remote PowerG, it must be connected via Wi-Fi, not PowerG
A Surety security service plan with Video
Surety Alarm or Surety Home with video add-on
Surety Protect
Surety Complete
One of the following Alarm.com compatible came…
Alarm.com customers with a 2GIG EDGE security panel can view live streams from their compatible Alarm.com video cameras right on the panel’s screen.
Feature requirements
To stream live video from the panel, users will need:
Service package A service package that supports at least one video device.
Panel hardware The 2GIG EDGE must be connected to your router’s or access point’s Wi-Fi network.
The Doorbell Camera and the 2GIG EDGE panel must be connected to the exact same device’s Wi-Fi …
