I have a Yale lock Z-Wave that is not connected
I had to do a reset on the Yale lock and now it is not connecting.
It shows malfunctioning and that it is not connected.
How can I get this to work again?
Thanks!
tyler
(Tyler)
April 12, 2023, 7:52pm
2
Happy to assist!
Steps on how to resolve malfunction for a variety of devices can be found through the below guide:
What is a Malfunction and How to Resolve
The Malfunction trouble condition indicates a device (an RF sensor, Z-Wave, Geo-Device, etc.) is unable to properly communicate.
Generally speaking, the issue can be resolved via the following means:
Verify that the device is still active and powered on.
Power cycle the device.
Verify there is nothing that could be interfering with communication, such as range (distance from sensor to panel, or Z-Wave device to nearest repeating node).
If applicable, …
If you reset the lock locally, it will need to be removed from the Z-Wave network, then re-added and a Z-Wave network rediscovery run.
More information on clearing/adding Z-Wave devices can be found in the below guide:
This guide is a reference on how to pair z-wave devices to your Z-wave compatible alarm panel.
If you would like to increase your current Z-Wave mesh network range and quality, see this post here.
One of the biggest rewards of owning an alarm system and utilizing Alarm.com is the ability to create your own smart-home network of Z-wave devices.
There is, however, a slight learning curve to the installation and troubleshooting when it comes to Z-Wave. Required steps unique to Z-wave (as oppos…
How do I uninstall the z wave?
tyler
(Tyler)
April 13, 2023, 1:17pm
4
This guide covers the various Z-Wave pairing processes with the Qolsys IQ Panel 2/2+ and the IQ Panel 4
1. How to Remove a Z-Wave device from the parent network.
An often overlooked step in the process. In order to remove a device from its parent network. Always do this first when adding a device, because it may still have network data saved within its Z-wave radio and this needs to be cleared before it can be added to a new panel.
Navigate to the Settings Tray and click Settings
Click Advanc…
Refer to the manual for your specific model of lock for the exact exclusion/inclusion command
Hi,
I tried to do this, but got this error when trying to remove the z waze device https://prnt.sc/E3U7F7S8b2kO and https://prnt.sc/dGJgLGLdDDS2
What am I doing wrong?
tyler
(Tyler)
April 19, 2023, 3:35pm
6
This indicates that the panel is too far from the device you are trying to clear from the Z-Wave network. When clearing/pairing Z-Wave Locks, the panel needs to be within a few feet or so. You can bring the panel closer to the lock by running the panel on battery power if necessary.
To do so safely:
Disarm the system
Unplug the power supply from the wall
Open the panel and disconnect the power cable from the panel.
If wall mounted, you may want to tape the cable to the wall so it does not get lost behind the wall
While running on battery backup, bring the panel closer to the lock for the clear and inclusion process.
Hi,
I am tryiong to connect to a device 1 foot from my wall panel and it is still not connecting. How can I get this to connect?
tyler
(Tyler)
April 19, 2023, 6:49pm
8
Are you clearing the Z-Wave device first? What is the make/model of the z-wave lock?
First you need to clear the Z-Wave device from the panel.
Then you need to Pair the Z-Wave Device to the panel
Lastly, once all Z-Wave devices have been paired, you need to run a Z-Wave network rediscovery.
Those steps are found here:
If applicable, …
