I’m looking for a new door lock, and it seems that there are locks listed on Alarm.com’s ecosystem page that are not on lists of compatible Qolsys 2 zwave devices. Should I assume that if something is not listed as compatible with Qolsys, that it shouldn’t be used even if it’s on Alarm.com’s page?
Also I also saw on Alarm.com’s page that Moen Flo and Phyn Plus are listed. Is there an ability to actually integrate them?
We have found that if items are on the ADC supported list they will generally work. The Qolsys list is a more limited set of devices that Qolsys has officially tested.
Yes, both of those integrations are available with the Water Management add-on
Interesting regarding water management. What features are available through Alarm.com for both?
For example, will I get alerts if a leak is detected? Will setting my alarm system to away make a corresponding change to Flo and Phyn so that they go into “away” mode? Lastly, what else is supported or becomes available with water management? Not a lot of info out there on that account feature…
Thanks. Is it possible to set Moen Flo or Phyn to its “away” mode from Alarm.com automations?
Also is it a local or cloud integration? Thinking of situation where internet goes down…. Obviously Alarm.com would communicate to Qolsys via cellular, but wouldn’t want Moen or Phyn to have issues then.
This is a new integration and documentation consists entirely of the above bullet points. If Away is a status applicable to the Moen or Phlyn app, it is likely this would be covered in automation rules (seems an obvious one-for-one automation opportunity).
I’ll see if I can confirm with Alarm.com and follow up here.
This is a cloud integration. The devices do not link directly to your panel.
