Alarm Panels Compatible With Surety
Systems that are Compatible with Surety
There are a wide variety of systems compatible with our service. With a 4G LTE Alarm.com compatible cellular module, you can use any of the following systems with Surety.
If you’re buying a new system, we recommend either the nami Agile Security System or the IQ Panel 5, depending on your home and needs. nami is the easiest to install: you set it up right in the Alarm.com app, which walks you through each step. The IQ Panel 5 is a more advanced, professional-grade panel that takes more effort and technical ability to set up. Both are described below.
The nami Agile Security System is a DIY-friendly system built on Alarm.com and designed to be self-installed in an hour or two. You set it up right in the Alarm.com app, which walks you through the installation step by step. Instead of a traditional alarm panel, a hub called the Pod uses Wi-Fi motion sensing to detect movement across whole rooms, combined with traditional door/window and PIR motion sensors. It’s a great choice for apartments, condos, townhomes, smaller homes, and small business spaces. For larger homes or more advanced setups, consider the IQ Panel 5. nami is currently available through early access.
  • Easy Step-by-Step Setup in the Alarm.com App
  • Starter Kit with Pod (hub with built-in siren), Keypad, Sensor Plug, Door Sensor, and PIR Motion Detector
  • Wi-Fi Motion Sensing that Covers Whole Rooms
  • Thread Mesh Networking
  • nami AI Cameras (Doorbell, Indoor, Outdoor, Battery, and Floodlight)
  • Works with Alarm.com Cloud-Connected Locks, Thermostats, Garage Doors, and Lighting
  • Cellular and Internet Communication with the Upcoming Pod 24
  • No Local Z-Wave Support Yet (Z-Wave bridge planned)
  • Fire, CO, Glass Break, and Medical Sensors Coming Soon
IQ Panel 5
The IQ Panel 5 from IQ Security (formerly Qolsys) is a great choice for larger homes and businesses, for anyone who wants the most capable platform, or if you have existing wireless sensors you want to keep using. As a professional-grade panel, it takes more effort and technical ability to set up than nami. It works natively with encrypted PowerG and PowerG+ wireless sensors. An optional IQ Card adds one legacy sensor radio (319.5MHz, 345MHz, or 433MHz), so you can keep using existing GE/Interlogix, 2GIG/Honeywell, or DSC wireless sensors.
  • Built in LTE and Dual-Band Wifi (2.4/5GHz)
  • 7 Inch Capacitive Touchscreen
  • Stream Alarm.com Video
  • PowerG+ Sensor Support (up to 128 sensors)
  • Optional Legacy Sensor Radio via IQ Card (319.5, 345, or 433)
  • Z-Wave Plus 800 Series with Long Range Support
  • Bluetooth Touchless Disarming
  • 13MP Panel Camera with Motion and Glass Break Detection
  • Two Way Voice
  • Up to 4 Partitions
Model numbers for the IQ Panel 5 by cellular carrier:
  • IQP5017: Verizon cell communicator. PowerG+ sensors. Z-wave automation devices.
  • IQP5018: AT&T cell communicator. PowerG+ sensors. Z-wave automation devices.
Either model can be paired with an optional IQ Card for 319.5MHz, 345MHz, or 433MHz legacy sensors. Only one legacy radio can be installed.
IQ 5 Hub
The IQ 5 Hub is a more affordable alternative to the IQ Panel 5. It has the same processor, PowerG+ radio, and Z-Wave Long Range support, but with a lower-resolution screen, a single speaker and microphone, and no camera.
  • No Panel Camera
Model numbers for the IQ 5 Hub by cellular carrier:
  • IQH5017: Verizon cell communicator, PowerG+ sensor radio
  • IQH5018: AT&T cell communicator, PowerG+ sensor radio
IQ Panel 4
The IQ Panel 4 is discontinued and no longer produced by the manufacturer. It has been replaced by the IQ Panel 5. Existing panels of this model can be used with our service. If you are purchasing a new alarm panel, use the IQ Panel 5 instead.
  • Built in Wifi Backup
  • PowerG Sensor Support (PowerG+ with firmware 4.6.1 or later)
  • One Legacy Sensor Radio (319.5, 433, or 345)
  • Network Firmware Updates
  • Panel Camera/Motion
  • Partition Support
Model numbers for the IQ Panel 4 by sensor compatibility:
  • IQP4001: Verizon cell communicator. 319.5Mhz sensors. PowerG sensors. Z-wave automation devices. (Z-wave sensors are not supported.)
  • IQP4004: AT&T cell communicator. 319.5Mhz sensors. PowerG sensors. Z-wave automation devices. (Z-wave sensors are not supported.)
  • IQP4002: Verizon cell communicator. DSC 433Mhz sensors. PowerG sensors. Z-wave automation devices. (Z-wave sensors are not supported.)
  • IQP4005: AT&T cell communicator. DSC 433Mhz sensors. PowerG sensors. Z-wave automation devices. (Z-wave sensors are not supported.)
  • IQP4003: Verizon cell communicator. 345Mhz sensors. PowerG sensors. Z-wave automation devices. (Z-wave sensors are not supported.)
  • IQP4006: AT&T cell communicator. 345Mhz sensors. PowerG sensors. Z-wave automation devices. (Z-wave sensors are not supported.)
IQ Pro
  • Built in Wifi and LTE
  • 8 Hardwired Inputs
  • Commercial Focused System
  • Programming and Installation App
  • 8 Partition Support
IQ 4 Hub
The IQ 4 Hub is discontinued and no longer produced by the manufacturer. It has been replaced by the IQ 5 Hub. Existing hubs of this model can be used with our service. If you are purchasing a new hub, use the IQ 5 Hub instead.
  • One RF Band (PowerG, 319, 345, or 433)
  • Partition Support
  • No Two Way Voice
Model numbers for the IQ 4 Hub by sensor compatibility:
  • IQPH054: Verizon cell communicator, PowerG sensor radio
  • IQPH058: AT&T cell communicator, PowerG sensor radio
  • IQPH051: Verizon cell communicator, 319.5Mhz sensor radio
  • IQPH055: AT&T cell communicator, 319.5Mhz sensor radio
  • IQPH053: Verizon cell communicator, 433Mhz sensor radio
  • IQPH057: AT&T cell communicator, 433Mhz sensor radio
  • IQPH052: Verizon cell communicator, 345Mhz sensor radio
  • IQPH056: AT&T cell communicator, 345Mhz sensor radio
IQ Panel 2+
The IQ Panel 2+ is discontinued and no longer produced by the manufacturer. Existing panels of this model can be used with our service. If you are purchasing a new alarm panel, use the IQ Panel 5 instead.
  • Partition Support
2GIG Edge
  • USB Updates
  • Honeywell Sensor Support
  • 2GIG Encrypted Sensors
  • Partition Support
2GIG GC3 and GC3e
The 2GIG GC3 and GC3e panels are discontinued and no longer produced by the manufacturer. Existing panels of this model can be used with our service. If you are purchasing a new alarm panel, use the IQ Panel 5 with a 345MHz IQ Card or the 2GIG Edge instead.
  • USB Updates
  • Partition Support
  • Encryption with e-Series Panels
2GIG GC2 and GC2e
The 2GIG GC2 is discontinued and no longer produced by the manufacturer. Existing panels of this model can be used with our service. If you are purchasing a new alarm panel, use the IQ Panel 5 with a 345MHz IQ Card or the 2GIG Edge instead.
  • Firmware Updates
  • Honeywell 345 Sensor Support
  • 4.3 Inch Resistive Touchscreen
  • 5 Inch Capacitive Touchscreen on GC2e
DSC Neo
  • Hybrid wired and wireless
  • Physical and Touchscreen Keypads
DSC Impassa
  • DSC 433 Sensor Support
  • Physical Keypad and LCD Screen
Simon XTi
The Simon XTi is discontinued and no longer produced by the manufacturer. Existing panels of this model can be used with our service. If you are purchasing a new alarm panel, use the IQ Panel 5 instead.
  • GE 319.5 Sensor Support
  • 3.5 Inch Resistive Touchscreen
  • 5 Inch Touchscreen on XTi-5 model
  • Discontinued by Manufacturer
Simon XT
The Simon XT is discontinued and no longer produced by the manufacturer. Existing panels of this model can be used with our service. If you are purchasing a new alarm panel, use the IQ Panel 5 instead.
NetworX
The Networx panel is discontinued and no longer produced by the manufacturer. Existing panels of this model can be used with our service. If you are purchasing a new alarm panel, use the IQ Panel 5 instead.
Concord 4
The Concord 4 panel is discontinued and no longer produced by the manufacturer. Existing panels of this model can be used with our service. If you are purchasing a new alarm panel, use the IQ Panel 5 instead.
DSC PowerSeries SEM
  • Supports PC1616, PC1832, PC1864
  • Requires panels that are version 4.20+
  • Adds Z-wave Automation Support
Honeywell Vista SEM
  • Supports Vista 10P, 15P, 20P, 21IP
  • Panels manufactured 2005 or later and version 3.1+
