Alarm.com Indoor/Outdoor Mini Bullet ADC-VC726
Overview
The ADC-VC726 from Alarm.com is a high-performance mini bullet camera optimized for indoor and outdoor video monitoring. Its compact design and outstanding 1080p HD quality video make the camera ideal for both commercial and residential video installations. The camera features a dust-resistant exterior casing with an IP67 rating and Power over Ethernet (PoE) capabilities.
Features
  • Power over Ethernet
  • IR night vision
  • 1080p HD video
  • IP67-rated waterproof & dust tight
    • This allows the camera to be mounted outdoors
    • IP-67 also protects against the effects of immersion in water to depth between 15 cm and 1 meter when immersed for 30 minutes
  • Video Analytics, Video Motion Detection, and sensor-triggered clips saved to the cloud
Included accessories
  • Camera
  • Camera stand
  • Three mounting screws
  • Three drywall anchors
  • Drill template
  • Waterproofing cap
  • T10 Torx wrench
  • Setup guide
Specifications
Live resolution options 1920x1080, 1280x720, 640x360
Recording resolution 1920x1080, 1280x720
Recording compression H.264
Image sensor 1/2.8" Progressive Scan CMOS
Lens 4 mm, F1.6
Angle of view 86°
Low-light sensitivity 0 lux with IR
IR range Up to ~95 feet (30 meters)
Image adjustments Flip, brightness, contrast, saturation, sharpness, exposure
Video motion detection 3 windows, adjustable sensitivity and threshold
Ethernet connection 10/100Mbps RJ-45
Operating temperature -22°F – 140°F (-30°C - 60°C)
Operating humidity < 95% (non-condensing) RH
Max power consumption 12 V DC ± 10%, 5W or PoE (802.3af), 6.5W
Dimensions (DxL) 2.76″ × 6.1″ (7 × 15.5 cm)
Weight 410 g (0.9 lbs.)
Ingress protection IP67
Compliance UL Listed
Network requirements
Minimum bandwidth 1.5 MBPS
PoE standard IEEE 802.3af
Installation and Setup
Troubleshooting
