anonimis1
(anonimis1)
November 23, 2025, 5:57pm
1
I just joined surety and I’ve lost the ability to add sensors ……. WHY?
i need to add a camera and flood sensor immediately. I need this access for future add-ons.
nicholas
(Nicholas)
November 23, 2025, 7:07pm
2
You should still have the ability to add sensors to your system in the panel programming.
You will need the installer or dealer code in order to access panel programming. If you need to reset your installer or dealer code, you can do so through the System Manager section of your Surety Account. Steps to do so can be found here .
Steps to program new sensors onto your system can be found in these guides:
This guide covers some common programming choices for the Qolsys IQ Panel 2 and 2+ alarm panels.
Below is the pathway taken at the panel to access sensor programming. We recommend choosing the Auto Learn Sensor feature.
Installer code or Dealer code is required as the Master code does not give you access to panel programming.
[Qolsys-Senosr-Programming]
After choosing Auto Learn Sensor, the panel will begin to listen for the sensor’s signal. It is at this point that you would tamper or trip…
This guide covers some common programming choices for PowerG sensors wth the Qolsys IQ Panel 2/2+, IQ Panel 4 and IQ4 Hub alarm panels.
Below is the pathway taken at the panel to access sensor programming. We recommend manually programming the sensor. Installer code or Dealer code is required as the Master code does not give you access to panel programming.
To do so, tap Settings > Advanced Settings > enter installer code > Installation > Devices > Security Sensors.
Use the Add Sensor option …
Steps to add a camera to your Alarm.com account can be found in this guide:
To enroll a camera, connect the camera to the local network, then associate the camera with the Alarm.com account.
There are three local options for connecting video devices to the network:
Ethernet,
Wi-Fi Protected Setup (WPS) Mode, and
Access Point (AP) Mode.
Bluetooth (ADC-V730, ADC-VDB775)
Some video devices can only be connected using some of those options, so verify which methods are supported before beginning the enrollment process.
Pre-enrollment checklist:
AC power adapter (requi…
