Hello, I just bought a ADC-VC727P and when I connect it through POE it just stays blinking green. There is also no option to add this specific device in the alarm.com app either.
I tried adding it using the MAC address but the app cant find it.
For reference I have a ADC-VC838PF that I connected earlier this year with no issues through POE.
I already tried resetting the camera to factory default via the button on the bottom. I also power cycled the camera and my router multiple times.
Blinking green indicates it can only communicate on the LAN. It has no internet connection. This typically means the nat/firewall settings are not allowing traffic to/from the camera.
What model of router are you using? Did you add any rules for the other camera when you set it up?
Is the camera physically installed right now or are you using a short patch cable to pair it first before installation?
I would recommend bench testing if you are not, with a short patch cable just so there is no question about the wiring, though I wouldn’t expect the blinking green on most cabling issues. Does it work using POE on a short patch cable?
If not, does it work using the barrel connector and power supply, not using POE?
It would be very strange for there to be router issues on one ADC camera and not the other. It makes me suspect the camera itself is the underlying issue.
Did you make any router changes, add any alternate devices, or update the router firmware in between installing the first camera and trying the second? Or were they added at the same time? A list of some POE capable models are below. I would think the VC727P would be a good choice, but any from the list below might work.
Warranty agreements are between the vendor and buyer, be sure to reach out to the vendor where the camera was purchased for details on how they handle warranty.
For the sake of posterity, I wanted to update that I reached out to the camera vendor who put us on a three way call with an Alarm.com tech that deemed the device defective. A full refund was issued.
Check to see which package you have and how many cameras can be added to your account. You might to upgrade your alarm.com package to add extra camera
And once you upgraded it
Then check if the camera came up on your phone.
Ok so I bought a ADC-VC726 and tried to connect it and I’m having the same issue as before of it not being recognized and being unable to add the device. When I type in the MAC address manually it matches the device but is unable to connect to it. I bought a new router thinking it could be that, still an issue. Bought a new POE switch, still an issue. Upgraded my service to 10 devices, still an issue. I don’t know what to do at this point and I’m really frustrated.
Is camera new or used?
Have you factory reset the camera?
Steps on how to install and factory reset the camera can be found here:
What error do you receive when trying to connect?
I am showing 2 other cameras connected and they respond to pings successfully. Were they connected without issue on the last router?
Currently, your plan supports up to 10 cameras, but only two are connected. Increasing camera support is unnecessary to resolve a camera connection issue, unless the issue is you are out of your allowed allotment of cameras.
