Bou
(Bou)
November 6, 2025, 2:11am
1
I need to know with a HARD YES or NO
Can i ADD the older model :ADC-IS-300-LP Image Sensor successfully to my
new iQ panel 4 with any problems / issues ?
Next big question : I am ditching my iQ panel 2 and cant even access the panel screen
because of all the jumping and jiggling that the screen consistently does.
( I will not be able to delete the ADC-IS-300-LP Image Sensor from the old iQ2 )
How would i switch this live motion cam from the iQ 2 to the iQ panel 4?
No. It is not compatible.
Per Qolsys, the IQ Panel 4 does not support the ADC Image Sensor daughtercard, and the available Zigbee daughtercard does not operate on the 900Mhz frequency used by the Image Sensor. It will not work.
PowerG Image Sensors are available as a replacement.
Sounds like you are referencing Image Sensors, like the one below. Is that correct?
https://iqsecurityproducts.com/image-sensor-2/
Those devices are not compatible with the IQ Panel 4, IQ 4 Hub, or IQ Pro.
If you are looking for motion detection that takes still images, you could use the DSC PowerG PG9934P. The PowerG Camera detectors can upload alarm and Peek-in Now images to Alarm.com only.
