I’ve been noticing on my IQ Remote that weather becomes unavailable at times. Not true on the IQP4. The IQ remote is paired via PowerG, but it also on WiFi. I notice this because I have enabled the Weather Clock screen saver and when weather failed the screen saver shows only the clock. Before I enabled the weather clock I would notice weather not working when I clicked the weather icon on the upper left and the popup screen would be blank where it would normally show 4 days of weather forecast.
I’m on 4.4.1. Is this a known issue or is there a way to debug this condition to understand better where this is breaking down?
I’ve only had the entire system set up a short while so it’s too early to notice a pattern. I’ve noticed it 3 times. Since I’m more or less letting the whole system bake a while after setting it up I hadn’t thought it was very critical.
I’ll try to keep tabs on it. It has not yet resolved itself. I’m unable to answer your questions about how it resolves since the system hasn’t been active that long and I haven’t been monitoring the weather closely on the remote. There doesn’t appear to be any issues with weather on the IQP4 that it is connected to so if I had to guess the issue is with how the remote is communicating with the IQP4 over powerg etc.
I have passed along the relevant data to Qolsys to see if this is a known issue on their end, or if they have any recommended trouble shooting steps to resolve. I will follow up once I have more information.
Thanks. It has not occurred today. At this moment the IQ Remote on my system is showing the weather clock and also will show the 4 days of weather when the icon on the upper left is clicked.
Did the logs show anything? If they want to send a debug build or enable some logging let me know. I’m a software engineer so I’m ok with testing some of this out.
Ok, while the weather hasn’t gone away on the IQ Remote I have noticed that one day is missing. So if I were to guess maybe the sync stops working and eventually you run out of forecast days. I have clicked the button to upload the logs.
