Vivint Flood/Water sensor
Does anyone know if the Vivint VS-FLD001-345 Water Sensor will work with Qolsys? I have a feeling it’s encrypted because I can’t get it to Auto -Learn.
Vivint sensors used with the Sky Panel and newer systems are proprietary and designed to only be functional with Vivint panels.
Here is a link to a compatible sensor list. Jump to the 345 Mhz section if you have that panel type.
Thanks!
