The most recent compatibility list comes from Qolsys and reflects the IQ Panel 2 firmware version 2.6.0.
The below list applies to IQ Panel 2+ software version 2.5.1 and higher.
PowerG (Long Range, Long Battery Life, Most Secure)
PowerG devices are compatible with all IQ Panel 2+ models but not with the the older IQ Panel 2.
Brand | Product | Part Number | Limitations |
PowerG | Door / Window Sensor | PG9945 | None |
PowerG | NEW Door / Window Sensor with AUX | PG9309 | Aux 2 Not Supported |
PowerG | Door / Window Vanishing Sensor | PG9975 | No Signal Test at Panel |
PowerG | NEW Door / Window Vanishing Sensor | PG9303 | None |
PowerG | Outdoor Door Sensor | PG9312 | None |
PowerG | Recessed Door Sensor | PG9307 | None |
PowerG | PIR Detector | PG9904 | None |
PowerG | Curtain PIR Detector | PG9924 | None |
PowerG | Outdoor Curtain PIR Detector | PG9902 | None |
PowerG | Mirror Optic PIR Detector | PG9974 | Anti-Masking Supported as Motion Event |
PowerG | Flat PIR Detector | PG9914 | Sensitivity Setting Not Supported / FW 4.0.0 or Higher Required |
PowerG | 360 Degree Ceiling-Mount PIR | PG9862 | None |
PowerG | Long Range 360 Degree Ceiling-Mount PIR | PG9872 | None |
PowerG | Outdoor PIR Detector | PG9994 | Anti-Masking Supported as Motion Event |
PowerG | PIR - Camera Detector | PG9934 | Limit of 5 Total PIR CAMs |
PowerG | Outdoor PIR - Camera Detector | PG9944 | Limit of 5 Total PIR CAMs |
PowerG | Dual PIR and Microwave Detector | PG9984 | Anti-Masking Supported as Motion Event |
PowerG | Glass Break Detector | PG9912 | None |
PowerG | Glass Break Detector | PG9922 | Test Button Only Sends Alarm after Tamper + Tamper Restoral |
PowerG | Shock Detector +Auxiliary Input | PG9935 | None |
PowerG | Smoke Detector | PG9926 | Test Button Only Sends Alarm after Tamper + Tamper Restoral |
PowerG | Smoke & Heat Detector | PG9936 | Test Button Only Sends Alarm after Tamper + Tamper Restoral |
PowerG | Smoke & Heat Detector | PG9916 | Test Button Only Sends Alarm after Tamper + Tamper Restoral |
PowerG | Carbon Monoxide Detector | PG9913 | Test Button Only Sends Alarm after Tamper + Tamper Restoral |
PowerG | Carbon Monoxide Detector | PG9933 | Test Button Only Sends Alarm after Tamper + Tamper Restoral |
PowerG | Flood Detector with Probe Disconnect | PG9985 | None |
PowerG | Temperature Sensor | PG9905 | None |
PowerG | Simple Keyfob | PG9939 | No Signal Test at Panel |
PowerG | Keyfob with System Status Indication | PG9929 | No Signal Test at Panel |
PowerG | Single Key Panic Button | PG9938 | No Signal Test at Panel |
PowerG | Two Key Panic Button | PG9949 | No Signal Test at Panel |
PowerG | 2-Way Wireless Keypad | WS9LCDWF9 | Limit of 5 |
PowerG | Indoor Siren | PG9901 | Limit of 16 Total Sirens |
PowerG | Outdoor Siren | PG9911 | Limit of 16 Total Sirens |
PowerG | Repeater | PG9920 | Limit of 8 |
319.5 MHz (S-Line, Interlogix/GE)
319.5 MHz devices are compatible with IQ Panel 2+ models QS9201-1208-840 and QS9202-1208-840.
Brand | Product | Part Number | Encryption |
Qolsys | IQ DW-S | QS1133-840 | Encrypted |
Qolsys | IQ Mini DW-S | QS1135-840 | Encrypted |
Qolsys | IQ Mini DW-S (Brown) | QS1136-840 | Encrypted |
Qolsys | IQ DW Mini Extended-S | QS1137-840 | Encrypted |
Qolsys | IQ Micro | QS1132-840 | Encrypted |
Qolsys | IQ Micro (Brown) | QS1130-840 | Encrypted |
Qolsys | IQ Recessed-S | QS1134-840 | Encrypted |
Qolsys | IQ Motion-S | QS1231-840 / QS1230-840 | Encrypted |
Qolsys | IQ Glass-S | QS1431-840 | Encrypted |
Qolsys | IQ Fob-S | QS1331-840 | Encrypted |
Qolsys | IQ Shock-S | QS1138-840 | Encrypted |
Qolsys | IQ Hardwire 16-F (Small Enclosure) | QS7133-840 | Encrypted |
Qolsys | IQ Hardwire 16-F (Large Enclosure) | QS7134-840 | Encrypted |
Qolsys | IQ Hardwire 16-S | QS7131-840 | Encrypted |
Qolsys | IQ Hardwire 8-S | QS7130-840 | Encrypted |
Qolsys | IQ Temp-S | QS5535-840 | Encrypted |
Qolsys | IQ Flood-S | QS5536-840 | Encrypted |
Qolsys | IQ Pendant-S | QS1332-840 | Encrypted |
Qolsys | IQ Fall Pendant | QS1314-840 | Encrypted |
Qolsys | IQ Mini DW | QS1115-840 | None |
Qolsys | IQ Mini DW (Brown) | QS1116-840 | None |
Qolsys | IQ Mini Extended | QS1117-PO1 | None |
Qolsys | IQ Door/Window | QS1100-PO1 | None |
Qolsys | IQ Tilt | QS1121-840 / QS5310-PO1 | None |
Qolsys | IQ Motion | QS1200-PO1 | None |
Qolsys | IQ Glass | QS1410-P01 | None |
Qolsys | IQ Fob | QS1310-PO1 | None |
Qolsys | IQ Smoke | QS5110-840 | None |
Qolsys | IQ Carbon | QS5210-840 | None |
Qolsys | IQ Temp | QS5515-840 | None |
Qolsys | IQ Flood | QS5516-840 | None |
Qolsys | IQ Doorbell | QS1119-840 / QS1605-840 | None |
Qolsys | IQ Pendant | QS6110-840 | None |
Qolsys | IQ Shock | QS1128-840 | None |
Qolsys | IQ Hardwire 16 | QS7121-840 | None |
Qolsys | IQ Hardwire 8 | QS7120-840 | None |
Qolsys | IQ Wireless Translator 345 | QS8130-P01 | None |
Qolsys | IQ Wireless Translator 433 | QS8140-P01 | None |
Qolsys | IQ Carbon | QS5210-PO1 | None |
Qolsys | IQ Smoke | QS5510-PO1 | None |
Qolsys | IQ Mini | QS1112-PO1 | None |
Qolsys | IQ Temp H20 | QS5500-PO1 | None |
Qolsys | IQ Pin Pad | QS1311-PO1 | None |
Qolsys | IQ Desk Fob | QS1312-PO1 | None |
Qolsys | IQ Hardwire | QS8120-PO1 | None |
Ecolink | Door Window Contact W/Bypass | WST-201 | None |
Ecolink | 4 Button Remote | WST-101 | None |
Ecolink | Recessed Contact | WST-221 | None |
Ecolink | Shock Sensor & Door Window Sensor | WST 302 | None |
Ecolink | Garage Door Tilt Sensor | WST 401 | None |
Interlogix | SAW Door/Window Sensor | 60-670-95R, NX-450 | None |
Interlogix | MaxLife Crystal Door/Window Sensor | 60-362N-10-319.5, NX-650 | None |
Interlogix | DesignLine Door/Window Sensor | TX-1010-01-1 | None |
Interlogix | DesignLine Recessed Door/Window Sensor | TX-1510-01-1 | None |
Interlogix | Glass Guard Crystal Sensor | 60-462-10-319.5, NX-656 | None |
Interlogix | ShatterPro Glassbreak Sensor | 60-873-95 | None |
Interlogix | DesignLine 4 Button Keyfob | TX-4014-01-2 | None |
Interlogix | 2 Button Keychain Touchpad | 60-607-319.5 | None |
Interlogix | Crystal Water-Resistant Pendant Panic | 60-578-10-95, NX-475 | None |
Interlogix | Crystal Micro Wristwatch Panic Button | 60-906-95, NX-474 | None |
Interlogix | Crystal Pet Immune PIR Motion | 60-511-02-95 | None |
Interlogix | Indoor Wireless Pet Immune SAW PIR | 60-807-95R | None |
Interlogix | Learn Mode Shock Sensor | 60-886-95 | None |
Interlogix | DesignLine Garage Door Sensor | TX-8010-01-1 | None |
Interlogix | Wireless Flood Detector | 60-744-95R, NX-695 | None |
Interlogix | SafeAir Wireless Carbon Monoxide Alarm | TX-6310-01-1 | None |
Interlogix | Crystal Carbon Monoxide Gas Sensor | 60-652-95, NX497 | None |
Interlogix | Supervised Wireless Smoke Alarm | TX-6010-01-1 (Date Code 11303 or newer) | None |
Interlogix | 135/200 Degree Rate-of-Rise Heat | HDX-135 / HDX-200 | None |
Interlogix | 135 Degree Rate-of-Rise Heat Detector | 60-460-319.5-LB | None |
Interlogix | Smoke Detector with Heat and Freeze | SDX-135Z | None |
Interlogix | Repeater with Crystal Transmitter | 80-922-1 | None |
Encore | FireFighter | FF319 | None |
Resolution | Door/Window | RE101 | None |
Resolution | Mighty Mouse | RE111 | None |
Resolution | Tilt | RE106 | None |
Resolution | PIR Pet Immune | RE110P | None |
Resolution | Glass Break Detector | RE109 | None |
Resolution | Smoke Detector | RE112 | None |
Resolution | Carbon Monoxide Detector | RE113 | None |
Resolution | Home Disaster Sensor | RE119 | None |
Resolution | Temp Range | RE105 | None |
Resolution | Medical Pendant | RE103 | None |
Resolution | Key Fob | RE100 | None |
Resolution | Hidden Panic Button | RE151 | None |
Resolution | PINPad | RE152 | None |
Resolution | Hardwire to GE Wireless Translator | RE108 | None |
Resolution | Honeywell to GE Wireless Translator | RE124HG | None |
Resolution | DSC to GE Wireless Translator | RE124DG | None |
Resolution | GE Repeater | RE120 | None |
Resolution | Universal Wireless Translator / Repeater | RE524X | None |
Resolution | Hardwire Translator | RE508X | None |
Resolution | Wireless Siren | RE116 | None |
345 MHz (2GIG, Honeywell)
345 MHz devices are compatible with IQ Panel 2+ models QS9201-5208-840 and QS9202-5208-840.
Brand | Product | Part Number | Device Limitations |
Honeywell | Door / Window Sensor | 5816 | Loop 1 - External Contact Loop 2 - Reed Switch |
Honeywell | Door / Window Outdoor Sensor | 5816OD | Loop 1 - External Contact Loop 2 - Reed Switch |
Honeywell | Door / Window Slim Line Sensor | 5920 L | Loop 1 |
Honeywell | Shock / Door Sensor | 5819WHS | Loop 1 - Shock Loop 3 - DW Ext |
Honeywell | Motion Sensor | 5800 PIR-RES | Loop 1 |
Honeywell | Auxiliary Pendant | 5802WXT | Loop 1 |
Honeywell | Key Fob | 5804 | None |
Honeywell | Key Fob | 5803-4 | None |
Honeywell | Temperature & Flood Detector | 5821 | Loop 1 - Freeze Loop 3 - Flood |
Honeywell | Carbon Monoxide Detector | 5800CO | Loop 1 |
Honeywell | Smoke Detector | 5808W3 | Loop 1 - Smoke Loop 2 - Heat Loop 3 - Freeze |
Honeywell | Glass Break Detector | 5853 | Loop 1 |
Honeywell | Tilt Sensor | 5822T | Loop 3 |
2GIG | Door / Window Sensor | DW10 | Loop 2 |
2GIG | Recessed Door Sensor | DW20 | Loop 1 |
2GIG | Panic Button | 2GIG-Panic-345 | Loop 1 |
2GIG | 4 Button Key Fob | 2GIG-Key2-345 | None |
2GIG | Motion Detector | 2GIG-PIR1-345 | Loop 1 |
2GIG | Glass Break Detector | 2GIG-GB1-345 | Loop 1 |
2GIG | Smoke Detector | 2GIG-SMKT3 | Loop 1 - Smoke Loop 2 - Heat Loop 3 - Freeze |
2GIG | Carbon Monoxide Detector | 2GIG-CO3-345 | Loop 1 |
2GIG | Gun Motion Detector | 2GIG-GNGRD1-345 | None |
2GIG | Hardwire to Wireless Translator | 2GIG-TAKE-345 | None |
433 MHz (DSC)
433 MHz devices are compatible with IQ Panel 2+ models QS9201-4208-840 and QS9202-4208-840.
DSC | 1 Button Panic | WS4938W | None |
DSC | 2 Button Key Fob | WS4949 | None |
DSC | 4 Button Key Fob | WS4939A | None |
DSC | 4 Button Key Fob | WS4959 | None |
DSC | Shock Sensor | EV-DW4927SS | None |
DSC | Door / Window Sensor | EV-DW4917 | None |
DSC | Door / Window Sensor | WS4945 | None |
DSC | Door / Window Sensor | WS4945NA | None |
DSC | Vanishing Door/Window Sensor | EV-DW4975 | None |
DSC | Motion Detector | WS4904P | None |
DSC | Motion Detector | WLS914 | None |
DSC | Glass Break Sensor | WLS912L | None |
DSC | Smoke Detector | WS4936 | None |
DSC | Smoke Detector | WS4916 | None |
DSC | Hold Up Switch | WLS928 | None |
DSC | Pendant Button | WS4938 | None |
DSC | Carbon Monoxide Detector | WS4933 | None |
DSC | Carbon Monoxide Detector | WS4913 | None |
DSC | Wireless Repeater | WS4920 | None |
DSC | Wireless Flood Detector | WS4985W | None |
