@vidail when I had them as custom zones they did not populate in the zone list at all. When I changed them to standard Zone Type 8 they did pull in but had status unknown. I tested a flood sensor to see if it cleared the unknown status and it did transmit as extreme temperature/ flood but for both the panic key and floods sensors. However, now the tested sensor will not clear its tripped status, so now need to try to reset sensor locally to see if I can clear the latched status. Not sure if it’s a failed sensor or deeper issue at this point. I found this other article about this same issue or similar: Change 5800 wireless device type - #4 by jwcsurety
@vidail Invited you to the PM I have on this issue with my zone list.
